Sponsored by:
Sponsored by:
really stupid issue
Old 05-28-2014, 01:04 PM
moosestang
moosestang's Avatar
After taking a PICTURE! and doing a little research, I believe it's called the electronic chassis control module. the part that says tyco is not a seperate piece, it's all one piece as far as I can tell. I didn't take the cover off the tyco part, didn't look like a good idea. i found a lot of used ones by searching the kit part number, $85, but they were off of 2005-2006 mustangs.
moosestang is offline
Old 05-28-2014, 01:11 PM
moosestang
moosestang's Avatar
http://www.ebay.com/itm/05-06-FORD-M...-/181274921077
There's a picture of it in this auction, yours might have a different part number. The tyco thing is just a connector and I doubt they are charging $800 for that. Most likely that's for the whole module.
Old 05-29-2014, 12:32 AM
ford4v429
ford4v429's Avatar
looks like the smart junction box? I think it will need programmed unless you find one with the exact same code suffixes- even then think some radios need programmed for theft prevention...maybe check with kevin casey over at themustangsource.com forums- he works at a dealer and is really into the parts research/help
how did your friend jump it wrong? leads backwards on the battery? any chance its just a fusible link or a maxifuse under the hood?
ford4v429 is offline
Old 05-29-2014, 02:45 AM
Art161
Art161's Avatar
Even if you do it properly, it's not a good idea these days to use one car to jump start another car. Back in the day it was fine, but now the electronics of both the jumper and the jumpee cars can be damaged by voltage spikes. It might not show up as an immediate catastrophic failure, but the electrical system can be weakened. An exception to this is a "smart" jumper cable that is in two pieces and connects in the middle. If it detects the cables are backwards, it won't complete the connection. It also has a device to damp any voltage spikes. I looked into this awhile back. At that time, the only cable I could find was made by Michelin, but it was only 12 feet long--way too short IMO.
The best way to jump start a car is by using a jump start device. You still have to be careful to connect the polarities correctly and to connect the negative cable to ground, not to the battery terminal. At least it won't produce voltage spikes if you use it properly.
Art161 is offline
Old 05-29-2014, 08:30 PM
LordRipberger
LordRipberger's Avatar
I agree with those saying try a junk yard. That has to be plenty of wrecked mustangs in there where this box was not destroyed.
LordRipberger is offline
cr620
10-03-2022 10:18 PM
lincolnshibuya
12-08-2015 04:37 PM
Thunderball
15
11-22-2015 11:49 PM
chrisdbassplayer
10-13-2015 06:53 PM
Bokeo
10-10-2015 08:28 PM
Quick Reply: really stupid issue
