installing shaker 1000 in base model mustang front amp wiring
NEED HELP!!! installing shaker 1000 in base model mustang front amp wiring
I need help from anyone that would have inffo on installing a shaker 1000 in a base model mustang 2005. We have the trunk amp and sub all working good. The problem we are having is getting the bottom front door sub's to work. We are trying to figure out what pins to use on the plugs that go into and out of the front amps in the drivers side kick panel. If someone has the shaker 1000 or 500 and could take a picture of the input and output wires and top of the plugs on the front amps that would be greatly appreciated. Or if someone have gone from a base model to a shaker 1000 or 500 and could give me some info. Thanks in advance!!!
if you look up shaker 1000 wiring on google you'll get like a million hits, I used this recently to decypher on my 2013 (though it's different) which wires were which when I installed a 5-channel amplifier powering the door subs, trunk sub, and door "components"
inyadreems
08-21-2015 09:10 AM
