Sponsored by:
Sponsored by:
Trany Service???
Old 05-31-2014, 12:43 PM
outceltj
outceltj's Avatar
that's a fair price for your tranny service. Beaware that when u beat on the car your tranny oil will get hot. The oil will leak out on the bell housing of the car. Not sure why ford did not install a catch can but they didn't. Anyway, just be aware of that. Its not a huge deal but something to think about. JDM sells a nice catch can for the trannys. I would also suggest a PA deep tranny pan. Easy to install and then you can check your tranny oil.
outceltj is offline
Old 05-31-2014, 12:44 PM
outceltj
outceltj's Avatar
By the way your car looks Sweet
outceltj is offline
Old 06-01-2014, 12:00 PM
GS81VETT
GS81VETT's Avatar
Yes the hood is after market as well as the head light pillers. I am learning about this car so bear with me. What hood shake are you guys referring to?
GS81VETT is offline
Old 06-02-2014, 09:31 AM
GS81VETT
GS81VETT's Avatar
Thanks! and Thanks!
GS81VETT is offline
Old 06-05-2014, 08:51 AM
BrianK
BrianK's Avatar
I did my own tranny fluid & filter change and installed a dipstick so I could refill easily. The stock pan has a drain with integral snorkel for refilling. This snorkel extends about 1" up into the pan. When I changed mine, I measured the amount of fluid that came out with each action.
1) Removed snorkel plug - 1.25 liters drained
2) Removed drain plug assembly- 1.6 liters drained
3) Removed pan - 1.65 liters residual in pan.
Total fluid required for refill - 4.5 liters.
So it appears my Tx was overfilled from the factory but I wanted to replace with the same amount of fluid that came out. The top of the snorkel is apparently the proper level for the Tx fluid.
I got some hydraulic fittings and hose from a local shop. With the pan off, I drilled a hole in the passenger side of the tranny pan and installed the fittings & hose and routed the hose up into the engine compartment. I also got a Tx dip stick at a wrecker. So now its easy to check level now and adding the fluid without trying to pump it up into the snorkel is the way it should be. Not sure how they put more in than what would go into the top of the snorkel. Anyway - the Tx shifts fine. After refill with 4.5 liters, I put the dipstick down the hose and marked the Tx oil level so I can check oil level now too.
I guess no factory dipstick so you have to take it somewhere to get it done - not!
BrianK is offline
Old 06-06-2014, 02:16 AM
808muscle
808muscle's Avatar
Or you can buy a deeper pan with a dipstick then changing the fluid is cake as you can fill from the dipstick. AM sells the deeper pan.
808muscle is offline
Old 06-08-2014, 05:26 PM
BrianK
BrianK's Avatar
I did look at the deeper pan - but it was pretty pricey so I went with the home made dipstick which works really well.
BrianK is offline
Old 06-08-2014, 05:47 PM
BrianK
BrianK's Avatar
Here is the link to the deeper pan with dipstick - $360 in case you're interested.
http://www.americanmuscle.com/perfor...span-0510.html
BrianK is offline
bradleyb
11-27-2015 07:50 PM
ChampInSD
10-02-2015 04:55 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Quick Reply: Trany Service???
