Chirping/Squeaking related to wheels(?) - MustangForums.com
Sponsored by:
Sponsored by:
Old 06-04-2014, 11:26 PM   #1
Widowmaker[X]
Default Chirping/Squeaking related to wheels(?)
Hey MFers,
'06 GT, just hit 50k miles. I've noticed a very faint chirping/squeaking noise (I believe) related to the front wheel area. It is speed dependent, meaning the frequency increases at higher speeds, which leads me to believe that it is something in the wheel area. From what I guess it occurs once per wheel rotation.
Any ideas?
Edit - The noise clearly gets worse when turning to the right and putting load on the left side. Conversly, if i am hearing the noise and corner to the left (de-loading the left side), the noise goes away. The noise goes away when any sort of brakes are applied.
Widowmaker[X] is offline   Reply With Quote
Old 06-05-2014, 01:41 AM   #2
kevsgt
kevsgt's Avatar
This is likely not the cause of your noise, since yours seems to relate more to speed, but there is a TSB out for the front lower control arms. I think one symptom is a creek noise going over bumps and such. Again, prolly a different problem, but thought I'd throw it out there.
kevsgt is offline   Reply With Quote
Old 06-05-2014, 03:07 AM   #3
drewsky
There is another thread posted tonight with a similar issue.. Could be dried up bushings that need a little lube and tightening. The speed should not have anything to do with it...?
drewsky is offline   Reply With Quote
Old 06-05-2014, 07:23 AM   #4
BrazenStang
Quote:
Originally Posted by Widowmaker[X] View Post
Hey MFers,
'06 GT, just hit 50k miles. I've noticed a very faint chirping/squeaking noise (I believe) related to the front wheel area. It is speed dependent, meaning the frequency increases at higher speeds, which leads me to believe that it is something in the wheel area. From what I guess it occurs once per wheel rotation. It does not get better or worse when turning or when under load. I notice no difference when braking or accelerating. I notice it more when coasting off throttle, but this is most likely just because there is less engine noise.
Any ideas?
Due to the frequency of the noise being speed related it is most likely due to brakes. Your rotor(s) could be worn unevenly/warped and rubbing on every rotation. It could also be a sticky brake pad(s) that is not releasing fully. I would re-do the brakes since they are probably about ready to be changed anyways.
If you recently had brakes done, then it could be a bearing. This is highly unlikely though because they usually make much more noise than you described and change noise when turning.
BrazenStang is offline   Reply With Quote
Old 06-09-2014, 04:22 PM   #5
Derf00
automatic or manual tranny?
Manual tranny could be the throwout bearing, when your foot is off the clutch the bearing squeaks. When your foot is on the clutch, it will not squeak.
If you're an auto then it could be a wheel bearing.
Derf00 is offline   Reply With Quote
Old 07-25-2014, 09:02 PM   #6
Widowmaker[X]
Hey guys. Still haven't managed to solve the problem.
Here is a video of the issue. Can really hear it at the beginning of the vid.
http://www.dailymotion.com/video/x2253m0_vid-20140608-184200_auto
Old 07-27-2014, 10:27 AM   #7
Widowmaker[X]
Had the pads checked out. Not even half worn.
The problem has now evolved in that it gets worse when turning to the right (loading up on the left side) and ceases when brakes are applied at any pressure.
Snow performance stage 2 MAF boos cooler install jwog666 Pipes, Boost & Juice 5 04-04-2016 05:23 PM
Starting Issue svfetter 5.0L (1979-1995) Mustang 9 10-05-2015 12:39 PM
20 inch Wheels a mistake on 2015 Mustang GT? mungodrums The New S550 2015-2017 Mustang 10 09-28-2015 11:54 PM
Polished wheels folivier Detailing 0 09-26-2015 03:28 PM
2 or 4 wheel alignment? lincolnshibuya V6 (1994-2004) Mustangs 1 09-24-2015 11:46 PM
