A/C not very cold - MustangForums.com
Sponsored by:
Sponsored by:
Old 06-17-2014, 12:19 AM   #1
ThaiCobra
Default A/C not very cold
Summer just hit here in Atlanta and daily temps are around 90'.
I noticed in traffic today, when I am running my A/C it doesn't seem very cold at all, its hardly cooling the car. I definitely remember when the car was new (2007) that it blew very cold air.
Any ideas about that? I changed my coolant 6 months ago, and I think my ratio may have been a little off. I think I could have used as much as 60% - 70% antifreeze to water. Could this be the issue? Just trying to think of everything.
THANKS
ThaiCobra is offline   Reply With Quote
Old 06-17-2014, 12:25 AM   #2
Lethaldosage423
Lethaldosage423's Avatar
coolant won't have anything to do with it,
Turn on your ac and see if the fans are on. they should come on within a few minutes.
If they don't come on, theres your problem.
Also, look at the AC compressor, the pulley spins separate from the clutch. See if the clutch is engaging at all.
If its NOT engaging, check for power/ground. No power, Check fuses or pressure switch
If you do have power it could be a bad compressor.
If the clutch is engaging on/off very fast, it could be low refrigerant.
The ac compressor clutch will not engage if the refrigerant is too low.
Check for oily spots on your ac condenser, quite often, a rock will puncture it and you'll loose all your refrigerant,
Best thing to do is to take it to a shop (independent/trusted of course) that does AC. have them evacuate it and recharge it. that will tell you how much was in there.
If you need help troubleshooting, keep the questions coming. I specialize in AC systems
i can go into detail about any of the things i said above if you need help.
-Chris
Lethaldosage423 is offline   Reply With Quote
Old 06-17-2014, 02:20 AM   #3
moosestang
Does the compressor kick on and off quickly? If it does, then you are low on freon. Mines been leaking at one of the quick connect fittings for years. I rarely use my a/c, don't sit in traffic and work in a freezer all day.
moosestang is offline   Reply With Quote
Old 06-17-2014, 12:11 PM   #4
Simon1
Last summer mine was blowing hot air on a 100+ day. Wouldn't get cold. I also hadn't used it in several months. Went home. Let the car sit and started it the next day. It worked fine and has worked fine after that. Don't panic yet.
It seems if I don't use it for a while it takes a little assistance to get working properly.
Simon1 is offline   Reply With Quote
Old 06-17-2014, 02:38 PM   #5
So_Cali
So_Cali's Avatar
Been having the same issue in my 2012 lately. We've had a few 100+ days and I'd get nothing but hot air blowing. Lately it hasnt been TOO bad, upper 80's, low 90's so it's bearable. Hoping it's just low on refrigerant and not a leak or something. Keep us posted if you find a solution.
So_Cali is offline   Reply With Quote
Old 06-17-2014, 02:43 PM   #6
bl817
bl817's Avatar
make sure its not overcharged as well. you can get a cheap gage from the local parts store that you attach to the low side port. only read the gage when the ac compressor is running or you will overcharge system. the ac being not very cold and not working are 2 different problems. mine is kinda cold and gets colder with the rpms and speed im driving. on a side note, turn your defrost on and see if the ac compressor comes on. it should as to remove humidity from cab.
bl817 is offline   Reply With Quote
Old 06-17-2014, 03:26 PM   #7
Goldenpony
Goldenpony's Avatar
My '06 wasn't getting very cold (100K miles) last year. I just bought one of those 134A kits, put in 1 can and it's nice & cold now. Easy Peasy. Just read the directions. Be sure to get a kit with a gauge.
Goldenpony is offline   Reply With Quote
Old 06-17-2014, 07:41 PM   #8
07 Cervini
If you are sitting on the highway in traffic, the engine isnt getting any quality air at all. In fact, the only air it is getting is probably well over 100 degrees due to the highway and all the other cars on the road. As traffic begins to unwind you should feel the A/C begin to get colder. Drive your car on an empty road and see if you still have the same problem.
07 Cervini is offline   Reply With Quote
Old 06-18-2014, 01:26 AM   #9
ThaiCobra
-Chris
Wow, thanks for the information Chris! But I have no idea what any of that stuff is...
where is the....
- AC compressor
pulley
clutch
- fuse for the AC
pressure switch
- AC condenser
Old 06-18-2014, 01:28 AM   #10
ThaiCobra
Quote:
Thats kinda what I am hoping, that I just need to put some of that freon stuff in it.
I'm taking it to my Autozone today, the guys there have been great and really seem to know their stuff.
Intake manifold replacement Dokilar 4.6L (1996-2004 Modular) Mustang 15 10-16-2015 08:13 PM
Street Action Tonight Explosive Street/Strip 17 10-02-2015 07:45 AM
Rough idle and vibrating 4cylinderplus2 V6 (1994-2004) Mustangs 9 09-30-2015 05:26 PM
Hello All RCS02v6 New Member Area 4 09-29-2015 01:46 PM
2001 V6 Sixer4Life New Member Area 4 09-28-2015 07:05 AM
