What a nightmare..... - Page 2 - MustangForums.com
Sponsored by:
Sponsored by:
Old 07-05-2014, 01:16 PM   #11
tx_zstang
tx_zstang's Avatar
Quote:
Originally Posted by AzPete View Post
Have you used a volt meter to check for power at any of the relays and plugs? That is the only way to really verify what is happening.
As a temporary fix to drive the car, you could wire the fans to a manual switch that you turn on when the car is running. That would also verify the fans work.
+1. You most likely have an electrical issue. you need to narrow it down to where the problem is, using a voltmeter. Could be that power to the relays is not there (although both low and high are different fuses), or the pcm signal to trigger the relays (ground one side of the coil) is not occurring. Until you track it down to a specific part of the circuit, you can't be sure what is causing it.
tx_zstang is offline   Reply With Quote
Old 07-05-2014, 07:24 PM   #12
defiance
defiance's Avatar
Any good writeups available for a manual switch that I can rig up in the mean time? Can't seem to find one for 05+ models
Also, one thing I have not tried is returning the factory tune to the car(have been running the same one for over 2 years now) and disconnecting the battery to reset everything. Maybe worth a shot.
defiance is offline   Reply With Quote
