Sponsored by:
Sponsored by:
What a nightmare.....
Old 07-03-2014, 03:22 PM
defiance
defiance's Avatar
Default What a nightmare.....
Two weeks ago I thought I had a defective cooling fan. I sent my newly acquired Ford Racing cooling fan (3 months old) back to Ford Racing and they sent me out a new one.
Today I received an email from Ford Racing saying that their engineers looked at the fan I have sent them, and after testing found the fan working just fine (both speeds). Later that day I receive the brand new fan, and sure enough after the install, it fails to start.
Once again I checked the relays, fuses, wiring and the fan plug. I even checked the underside of the fuse box to make sure there are no burn marks as one member recommended. Everything looks fine. I am completely stuck guys, I do not even know where to begin other than putting it in a shop, which sucks, for a simple cooling fan issue.
defiance is offline
Old 07-03-2014, 07:08 PM
charliebrown266
charliebrown266's Avatar
does the fan come on if you turn the a/c on? have you checked the thermo switch to see if its working?
charliebrown266 is offline
Old 07-03-2014, 09:01 PM
defiance
defiance's Avatar
No it does not turn on with ac either. What is a thermo switch, the thermostat ? I replaced the thermostat 3 months ago as well, but I can check it again if that's what you are referring to.
defiance is offline
Old 07-03-2014, 10:01 PM
AzPete
AzPete's Avatar
The fans operate according to temps of the engine plus they kick on high when the a/c is turned on. Need to locate those sensors and see if they are functioning. Cannot direct you on their location at this time.
AzPete is offline
Old 07-04-2014, 06:57 AM
jsimmonstx
jsimmonstx's Avatar
Fan comes on based on cylinder head temp. Does your instrument cluster temperature gauge appear to work?
jsimmonstx is offline
Old 07-04-2014, 08:45 AM
defiance
defiance's Avatar
Yes, the gauge works just fine. And to followup on AzPete's post, I believe our cars only have one sensor, water temperature sensor in the thermostat housing in a v6, and a Cylinder head temperature sensor in the v8.
defiance is offline
Old 07-04-2014, 08:47 PM
charliebrown266
if the fan doesn't come on with the a/c i would say it's not the thermo switch! have you checked all your fuses and the relay
Old 07-04-2014, 10:45 PM
defiance
defiance's Avatar
Yeah, checked them today for the third time. Was hoping for a miracle. This is the most frustrating problem I've had with the car
defiance is offline
Old 07-05-2014, 08:29 AM
AzPete
AzPete's Avatar
Have you used a volt meter to check for power at any of the relays and plugs? That is the only way to really verify what is happening.
As a temporary fix to drive the car, you could wire the fans to a manual switch that you turn on when the car is running. That would also verify the fans work.
AzPete is offline
Old 07-05-2014, 10:38 AM
slickman
slickman's Avatar
Pull the relays out and bench test them.
slickman is offline
