Sponsored by:
Sponsored by:
Oil filter tried to win....but I wouldnt quit!
Old 07-07-2014, 03:05 PM
Derf00
Gentleman's Relish
Derf00's Avatar
I use the band wrenches that use a rubber type material instead of metal for the band itself. Better Grip.
You can also see if you can find a socket style filter wrench that fits filters that have the same size base your wrench fits. I have yet to find a filter that a properly sized socket style filter wrench can't get off.
Derf00 is offline
Old 07-08-2014, 07:35 AM
Norm Peterson
Norm Peterson's Avatar
I don't think I've ever crushed an oil filter by using a band wrench. Both of my band wrenches are all metal, and one of those was eventually DIY-modified to fit a much smaller diameter filter than the one it was originally purchased for.
Maybe that's because I set the band close to the end of the filter where the end of the filter provides maximum resistance to crushing?
Norm
Norm Peterson is offline
Old 07-08-2014, 09:15 AM
dcarlinf1
dcarlinf1's Avatar
On other cars I have used the screwdriver method but on my '11 GT I tighten by hand and loosen by hand. Motorcraft filters every time. I've done about 8 oil changes now and never a problem with the filter.
dcarlinf1 is offline
Old 07-08-2014, 11:24 AM
Simon1
Simon1's Avatar
The only time a filter has stuck on any of my cars is when a shop put the filter on too tight. I only put them on by hand, I take them off by hand. And I only change my oil about one time a year.
Simon1 is offline
Old 07-08-2014, 06:54 PM
Nuke
Nuke's Avatar
I've been doing oil changes since the 70's and for the past 20-30 years, I've owned anywhere from 2 to 5 vehicles. The only times I crushed a filter or used the screwdriver method were on 2 or 3 factory-installed, torqued by a gorilla filters. As Norm stated, I seem to have no issues, even with tight filters, using an all metal band type wrench applied near the end of the can.
Nuke is offline
svfetter
10-05-2015 11:39 AM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
wraith777
09-28-2015 10:49 AM
treesloth
09-28-2015 07:03 AM
09-25-2015 09:06 AM
Quick Reply: Oil filter tried to win....but I wouldnt quit!
