Sponsored by:
Sponsored by:
did i mess up my deck panel? what can/should i do?
Old 08-06-2014, 09:28 AM
RenGen
Banned
RenGen's Avatar
Default did i mess up my deck panel? what can/should i do?
I installed it a year ago and did what the AM csr lady told me, which was to clean the area with a bowl of dish soap water, then rinse+dry - then wipe with the alcohol pad, then peel the 3m tape and put the panel on, but since then a couple of people told me that dish washing soap strips away wax and clear coat and with all the water that gets trapped behind the panel, the area is probably rusted as hell now - do you guys think its alright? I don't want to peel it off just to see everything's fine, but I don't want to ignore it and find out couple years from now my whole trunks rusting off, tough choice.
RenGen is offline
Old 08-06-2014, 10:22 AM
bl817
bl817's Avatar
you should be fine. the dish soap isn't the best for car washing but it does not strip the clear coat. the alcohol wipes got rid of the wax if used properly. the water should drain out fairly well depending on where the tape is and how much etc..
bl817 is offline
Old 08-06-2014, 10:31 AM
BrazenStang
BrazenStang's Avatar
Dish soap is good for cleaning contaminants and wax off of the car. Which is what you want so that the 3M tape sticks well. Your clear coat and paint are going to be fine to protect the metal under the decklid panel.
Waxes are not for protecting against rust. They protect the paint and clear coat from UV rays and other environmental junk so that the paint lasts longer. Any paint under the decklid panel is shaded/protected by the panel. You should be in good shape.
BrazenStang is offline
Old 08-06-2014, 01:19 PM
SPARTAN VI
SPARTAN VI's Avatar
RazorGT, is that you?
SPARTAN VI is offline
Old 08-06-2014, 02:54 PM
gmoran1469
gmoran1469's Avatar
What knucklehead told you that dish soap will strip paint?
gmoran1469 is offline
Old 08-06-2014, 06:46 PM
E_cox310
E_cox310's Avatar
The return of RazorGT???
E_cox310 is offline
b8checker
10-08-2015 12:55 PM
UrS4
10-03-2015 06:23 AM
jrrhd73must
10-02-2015 09:17 PM
breaking
10-02-2015 01:27 PM
b8checker
09-30-2015 07:11 AM
Quick Reply: did i mess up my deck panel? what can/should i do?
