Sponsored by:
Sponsored by:
No 09' S/C kits?
Old 08-11-2014, 07:12 PM
gmoran1469
gmoran1469's Avatar
Default No 09' S/C kits?
Just looked at the Paxton and Vortech S/C kits and both don't offer a "complete" 09' kit. Just a tuner kit, which is everything but the fuel system upgrades and the ecm reprogramming. Why don't they offer kits for the 09' that have these things?
gmoran1469 is offline
Old 08-12-2014, 10:06 AM
Simon1
Simon1's Avatar
It's because you are destined for a twin screw......
J/k
Not sure why they do that, but it's easy to fix. Buy a GT500 pump kit and if you already have a tuner you should be good. Might and probably will need a Mafia for your MAF sensor or a different MAF if it doesn't come with one.
Simon1 is offline
Old 08-12-2014, 01:18 PM
So_Cali
So_Cali's Avatar
Thats weird, I was under the assumption that 05-09, even the 10s were all the same.
So_Cali is offline
Old 08-12-2014, 01:22 PM
SSG Steggy
SSG Steggy's Avatar
Twin Screw
Wish they had one for the 3.7L!
SSG Steggy is offline
Old 08-12-2014, 03:00 PM
Derf00
Gentleman's Relish
Derf00's Avatar
No, in 07 Ford made some changes to the cooling system. Depending on your FI kit you may either need to upgrade the cooling system in your 05-06 to match the 07+ or the kit comes with the needed parts.
There are a few other minor differences between 05-06 and 07+ but each FI kit will address them as needed.
2010 has a few minor differences too.
http://www.edelbrock.com/automotive/...-mustang.shtml
http://www.vortechsuperchargers.com/images/2.pdf (note the different parts lists for 05-06 and 07-08 and 2010...hmm no mention of 2009.)
http://www.paxtonauto.com/product.php?id=103 (again note the different part numbers (and prices) for 05-06 and 07+.
Derf00 is offline
Old 08-12-2014, 04:07 PM
americaniron
americaniron's Avatar
I believe Brenspeed and others sell complete packages for your 09. Even though the link says 05-08, their add says it's a complete package and that it will fit the 09 too. Call them and ask. I know they use their tunes loaded onto an SCT tuner.
But unless you are set on a centrifugal supercharger, I would suggest going with a positive displacement one like a roots, or twin screw system.
http://www.brenspeed.com/05-08-musta...rchargers.html
americaniron is offline
Old 08-12-2014, 04:16 PM
gmoran1469
gmoran1469's Avatar
It's gonna be twin screw or centri. Not sure yet, still trying to do more research. I see a lot of people complaining of heat soak with the twin screw.
Old 08-12-2014, 04:41 PM
So_Cali
So_Cali's Avatar
http://www.vortechsuperchargers.com/images/2.pdf (note the different parts lists for 05-06 and 07-08 and 2010...hmm no mention of 2010.)
Thanks for the info, I had no idea. The more you know lol. +1
So_Cali is offline
Old 08-12-2014, 07:41 PM
dlazrael
dlazrael's Avatar
I haven't noticed that much heat soak, how hard are you running on a consistant basis? You could also go for something like KBs liquid cooled systems. I absolutely love my Whipple 2.3, it's got power from the word go... there's no lag time. I was originally set on centri back in 05 for my 03 Mach... because it was a mach, but research shows the PD/TS is alot better....
What are your end goals? Racing? Auto X? Fun factor? *** plant factor?
But in the end. FEEL THE BOOST!
dlazrael is offline
Old 08-12-2014, 09:26 PM
gmoran1469
gmoran1469's Avatar
street car but plan on having it for a while and eventually trying to hit 650 rwhp at least
Quick Reply: No 09' S/C kits?
