Sponsored by:
Sponsored by:
holy crap i almost crashed
Old 09-04-2014, 08:36 PM
13'GT Black
13'GT Black's Avatar
Default holy crap i almost crashed
Just got home from airport, decided to have some fun on the way and hear my roush wot for the first time. Cruising at 80mph floored it and car violently jerked to my left, it scared the crap out of me. At first i thought was a slick spot on the road, so i tried again same thing happened but this time i was more prepared. Im thinking its alignment problem since traction light didnt come on. It would of been very unfortunate if i did lose control..... Guess i have to vist an alignment shop tomorrow.
13'GT Black is offline
Old 09-04-2014, 08:45 PM
siggyfreud
siggyfreud's Avatar
Some massive torque steer going on. Sure it's not fwd . Could actually be tire related.
siggyfreud is offline
Old 09-04-2014, 09:24 PM
13'GT Black
how so?
Old 09-04-2014, 10:12 PM
siggyfreud
siggyfreud's Avatar
Tire that is worn unevenly or conical can cause it.
If you're only feeling the pull under acceleration I'd guess it's more likely a worn suspension component than alignment. Alignment you'd generally notice some all the time. Under acceleration you're shifting weight on the suspension which is where you'd notice a worn bushing or something.
Old 09-04-2014, 10:24 PM
13'GT Black
Tires seems fine except for slight feathering. Theres a slightly left pull under normal driving too. Its not bad but under wot its violent. I think its alignment issue. Tire kingdom dont display caster, im wondering if i knocked it out spec when i hit the big pot hole a month back
Old 09-05-2014, 04:25 AM
dawson1112
dawson1112's Avatar
Likely a worn lower rear control arm bushing.
dawson1112 is offline
Old 09-05-2014, 06:38 AM
jz78817
jz78817's Avatar
On a 2013? I think you're just losing traction somehow.
jz78817 is offline
Old 09-05-2014, 07:28 AM
dawson1112
dawson1112's Avatar
Yea you wouldn't think on a 2013 anything would have worn out , but if his traction control is turned on a working it should have cut power instantly to the tires keeping him from loosing any traction .
Old 09-05-2014, 08:07 AM
jz78817
jz78817's Avatar
it's a reactive system, it can only kick in after it detects wheelspin. on a damp road I can break the tires loose on my car in 3rd gear easy, and if the road is crowned it will start to fishtail before advancetrac gets on the job.
methinks the OP is exaggerating just a bit.
jz78817 is offline
Old 09-05-2014, 09:55 AM
13'GT Black
im not.... it was a very violent jerk to left. It felt like someone yank my steering wheel soon as i floored it. Traction control light didnt come, im assuming its my alignment. Im getting it checked out in a hour.Suspension shouldnt be worn already since its a 13 with 12k miles.
Quick Reply: holy crap i almost crashed
