2011 hood bubbling paint
#21
Deysha, I too had paint bubbling but was able to catch it in time before my warranty expired. Now that Ford fixed it, if (God forbid) for some reason the corrosion came back, will Ford fix again? Their workmanship should be guarantied no?
#22
#23
A Ford Service manager told me that the only cure for it is an after market hood.
#25
Deysha
#26
Talked to ford today saying they won't pay for it cause it hasn't eaten all the way through
#28
#29
if the root cause is iron contamination as has been said, then water contributes. Simply sticking aluminum and iron together won't cause corrosion without an electrolyte. When water comes in (especially salt water) the two dissimilar metals generate a tiny voltage which erodes the more reactive aluminum.
#30
Corrosion coverage only applies if the corrosion causes perforation (holes) in body sheet metal panels. If corrosion does not cause perforation (holes), or is the result of usage and/or environmental conditions, corrosion warranty would not apply.
Rust caused by exposed sheet metal from accidents or normal wear and tear are not defects in material or workmanship. The paint on the vehicle is covered under the terms of the Bumper to Bumper Warranty.
Corrosion Perforation Warranty coverage begins at the Warranty Start Date and lasts for five years, regardless of miles driven.
The time, distance, and limitations of warranty coverage may vary depending upon the model year of the vehicle.
Also, as per your warranty guide:
(3) Your vehicle’s body sheet metal panels are covered for an extended
Corrosion Coverage Period, which lasts for five years, regardless of miles
driven. The extended warranty coverage only applies if a body sheet
metal panel becomes perforated due to corrosion during normal use due
to a manufacturing defect in factory-supplied materials or factory
workmanship.
I hope this helps.
Deysha
