Sponsored by:
Sponsored by:
Steeda triple pass heat exchanger. WTF!
Old 09-20-2014, 10:58 PM
  #21
2007CalSpec
2007CalSpec's Avatar
I bought new bolts, lock washers, and flat washers. Bolts are M6-1.0 x 16 and washers are 6mm or M6. Got everything installed.
New bolt and washers (left). Old bolt and washers (right). It's obvious the old bolts are too short if you include the washers.
New bolts & washers installed.
Finished! I had to add an extra washer to the four bolts of one fan so the bolts don't contact the fins. I added blue loctite on all bolts.
Hopefully anyone who does this mod doesn't run into the same issue I did.
2007CalSpec is offline
Old 09-22-2014, 02:31 AM
  #22
2007CalSpec
Pics of the install I did today. I thought I had to buy a new IC pump because the fluid wasn't moving in the reservoir. I later found out I had to burp the system. Doh!
Old 09-22-2014, 08:46 PM
  #23
2007CalSpec
The dual Spal fans are awesome. You can really hear them. Toss a towel at the HE and it will stick to it.
Old 09-23-2014, 11:53 AM
  #24
Simon1
Simon1's Avatar
Yeah, use locktite or get a different bolt. I always go to my local fastener company and they will match thread and length of choice.
Simon1 is offline
TCStangerv6
10-11-2015 05:57 PM
Florida Regional Chapter
09-30-2015 08:04 PM
guitarman376
09-30-2015 05:54 PM
UrS4
09-30-2015 10:13 AM
09-24-2015 09:18 PM
Quick Reply: Steeda triple pass heat exchanger. WTF!
