Sponsored by:
Sponsored by:
JLT 3 CAI Filter keeps falling off
Old 09-29-2014, 07:03 AM
kevsgt
kevsgt's Avatar
Default JLT 3 CAI Filter keeps falling off
I've had my JLT 3 CAI for a year now, pictured here.
Three times now the filter has fallen off while driving! When this happens, the car sputters a bit and then shuts off power and locks up. I tried tightening the hose clamp as tight as possible. I tried slightly looser. What can I do to give it better grip and not fall off?? Has anyone else experienced this?
kevsgt is offline
Old 09-29-2014, 08:52 AM
hootie_john
hootie_john's Avatar
I had the same problem. I ended up fabbing a brace out of some angle iron and put it in the filter box to keep the filter from "sliding" off the tube. It's about 6-8" long, and runs along the edge of the filter element. I used some existing holes to attach it.
hootie_john is offline
Old 09-29-2014, 04:25 PM
scottmach
scottmach's Avatar
Try using T-Bolt clamps.
scottmach is offline
Old 10-01-2014, 08:36 AM
05 Mustang
05 Mustang's Avatar
That stinks....
Not sure how often you wash your car, but maybe try including a "filter check" when you do. This should help prevent that from happening.
05 Mustang is offline
Old 10-01-2014, 02:20 PM
algregory
algregory's Avatar
Likely more years ago than you've been alive I was a Jet Engine Mechanic for the USAF. I kept a spool of .032" safety wire and I still use it when the need comes up. Can you see a point on the air filter and an appropriate place on the CAI or the air box to wire the two together? That will certainly fix the problem! Otherwise you need to fatten up the CAI tube. I've also found bicycle inner-tube rubber to be handy at times, or, you could simply put a couple of those healthy size rubber bands on the CAI tube before you put the filter on.
algregory is offline
Old 10-01-2014, 02:37 PM
JTS64
JTS64's Avatar
Default Try X-Treme Tape
I had the same issue and I used some of this tape my Dad had. It is called X-Treme Tape made out of silicon rubber.
JTS64 is offline
Old 10-02-2014, 09:33 AM
So_Cali
So_Cali's Avatar
Kind of glad I didn't go with the JLT. Sounds like a pretty serious issue, wonder if the company knows about this? Good luck getting that fixed...
So_Cali is offline
Old 10-11-2014, 05:43 PM
kevsgt
kevsgt's Avatar
Thanks, but how would that clamp it better than the current method? Both apply force in the same way, circumferential around the tube, right?
kevsgt is offline
Old 10-11-2014, 06:42 PM
scottmach
scottmach's Avatar
No T-Bolt clamps have a much better clamping force hence the reason they come with most turbo kits.
Old 10-11-2014, 10:51 PM
Simon1
Simon1's Avatar
Mine never fell off. I wonder if there is something on the surfaces making it slick.
Simon1 is offline
Quick Reply: JLT 3 CAI Filter keeps falling off
