Check Engine Light --> Cam sensor
It will keep charging, the problem is it leaks AC current into your DC system and causes sensors to go haywire. It could potentially damage electronics. I replaced mine with a PA alternator from americanmuscle.com as a preventative maintenance. I still have the stock one sitting on the shelf.
With 32k and 8 years old that would probably be a good idea for me too. I would hate to have it fail on race night.
Most likely nothing but getting stranded on the side of the road, which is what happened to me.
But, damaged electronics is possible. The usual thing that would happen is your battery would get damaged, but, it doesn't always happen. Mine was fine.
