Sponsored by:
Sponsored by:
Check Engine Light --> Cam sensor
Old 11-04-2014, 12:20 AM
  #21
tx_zstang
tx_zstang's Avatar
The alternator can still be "charging", i.e, putting out "over 12 volts", and it not be charging properly. The "cam sensor codes", specifically p0304, will come on when voltage drops to around 12.4 - 12.8 volts when the car is running. I've watched it happen when my alternator started "going". Normally the voltage will be around/over 14 volts for a properly charging system. It'll start dropping gradually and fluctuating, and eventually still be running in the 12-13 volt range.
You should be able to measure and monitor the voltage, not just at idle, but when running and driving it around, you'll see what I mean.
Or just change the alternator.
tx_zstang is offline
Old 01-25-2015, 04:34 PM
  #22
BeastMachine67
BeastMachine67's Avatar
Oh wow, I completely forgot to update this! lol
I changed out the alternator and BOOM problem is gone.
BeastMachine67 is offline
djbigskrilla
09-20-2022 01:04 AM
mirandaandjimmy
11-16-2015 08:51 AM
labudski
08-24-2015 07:23 AM
microgt
08-20-2015 07:12 AM
mweiland
08-13-2015 05:11 PM
Quick Reply: Check Engine Light --> Cam sensor
