Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2014 Mustangs
Sign in using an external account
Register Forgot Password?
Search
2005 - 2014 Mustangs Discussions on the latest S197 model Mustangs from Ford.
Sponsored by Latemodel Restoration
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-06-2014, 12:49 PM   #1
Goldenpony
Goldenpony's Avatar
Default Power window problem-Help!
Got a real head stomper here. The window on the pass. side just stopped working. When I kept hitting the down button the window just moved slightly. Kind of made a little machine gun noise.. Wouldn't do anything when I would hit the up button. When i would be hitting the down button, I saw little bits of water coming out of the washer nozzles.
I took it to my buddy that has a mostly Mustang shop. He pulled the whole regulator assy. out . He said it looked OK. He thought it was the motor. He got a new motor, but it did the same thing.
He's called in help from another shop and they're trying to figure it out. One of the first things I checked was for wetness on the pass. side carpet (thinking the SJB had gotten wet,)
but carpet was dry as a bone. really weird.
__________________
2006 Premium GT Convertible
Screaming Yellow, Black Top
Michelin Pilot Super Sport tires
18" "Fanblade Wheels"
CORSA Performance exhaust
Brenspeed 87 octane performance tune
MGW Shifter
Goldenpony is offline   Reply With Quote
Old 11-06-2014, 06:41 PM   #2
Goldenpony
Goldenpony's Avatar
Default Window problem, continued
Looking more like a SJB problem. When you try to activate the window washer, the headlights go out, dash lights flicker.
__________________
MGW Shifter
Old 11-06-2014, 11:24 PM   #3
edwin108
edwin108's Avatar
Vehicle: 2010 GT
shlbygt500 shlbygt500
Are your battery terminals clean?
__________________
2010 Mustang GT Premium Grabber Blue / 4.6L 3V / 5MT / 401A / Security / HID / Comfort / TrackPack / 3.73
Ford Racing Hot Rod Cams / Steeda CAI / Steeda CMDPs / Bama Tunes / UPR Oil Catch Can / Shaftmasters 3.5" Aluminum DS
edwin108 is offline   Reply With Quote
Old 11-07-2014, 06:20 PM   #4
Nuke
Nuke's Avatar
Vehicle: 2007 GT
Send a message via AIM to Nuke Send a message via Yahoo to Nuke Send a message via Skype™ to Nuke
Water leak? If it's the SJB, the only thing I know that has caused problems with it IS the infamous water leak.
__________________
Rick
07 GT Prem: Alloy, MT, 3.55's, Steeda CAI w/Brenspeed tunes, FRPP Stingers, 275/40/18 Goodyear Eagle F1 A/S on SVT Cobras (OE GT500's), 14" shorty, Wheelskin side scoops & qtr window louvers, A-H rear window louvers, SHR honeycomb blackout panel, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
06 V6: Legend Lime, Pony Package, 14" shorty, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
Nuke is offline   Reply With Quote
Old 11-07-2014, 08:38 PM   #5
Goldenpony
Goldenpony's Avatar
Quote:
I'm assuming that is what the problem is. I have an appointment to take her into a shop Tuesday. They have a certified Ford Technician working there. Hopefully he can straighten it out.
__________________
MGW Shifter
Old 11-12-2014, 06:13 PM   #6
Goldenpony
Goldenpony's Avatar
Default TA DA- Happy Dance!
Well, got my baby back all better. I was convinced it was something like the SJB or something real pricey. Know what it was? A loose ground. Had to be from the factory 'cause nobody's ever been in there (behind the fuse block) but me and I didn't do it. There was a stud with a ground wire on it with a nut. The nut was cross threaded and the nut wouldn't tighten down any more. The tech just moved the wire to an adjoining bolt and problem solved. Cost me $80 but worth every dime. That even included putting the door all back together. I had left it apart and took it to them that way. Sometimes things work out OK.
__________________
MGW Shifter
Old 11-12-2014, 06:28 PM   #7
jz
jz's Avatar
Vehicle: 06 mustang GT
Wow. That's amazing! Good thing it wasn't due to water, or the SJB. That could have been pricey.
__________________
06 GT. Steeda Hood, Bumper, F&R sway bars, strut tower brace, struts/shocks, sport springs, HD strut mounts, UDP's, delete plates. Hawk Brake pads. Power Slot Rotors. Goodridge Braided brake Lines. BMR combo UCA, combo/adj LCA's, LCA relocation brackets, adj panhard bar, panhard bar brace. Pro 5.0 shifter. K&N CAI. Magnaflow Magnapacks cat back. FRPP 4.10's. BAMACHIPS SCT 93 tune.
jz is offline   Reply With Quote
Old 11-21-2014, 05:18 PM   #8
Nuke
Nuke's Avatar
Vehicle: 2007 GT
SO glad it wasn't the SJB.
__________________
Rick
Old 11-21-2014, 07:36 PM   #9
Goldenpony
Goldenpony's Avatar
Thanks guys. Yea, very glad it wasn't an SJB issue. Dodged that bullet.
__________________
MGW Shifter
MustangForums
Ford Mustang
Paid Advertisement
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Emails Backup
