Sponsored by:
Sponsored by:
New PA Alternator
Old 11-21-2014, 06:37 PM
Goldenpony
Goldenpony's Avatar
Alternator & power wire kit go in in the morning. Fingers crossed.
Goldenpony is offline
Old 11-21-2014, 08:53 PM
roegs
roegs's Avatar
Originally Posted by edwin108
It can't hurt to use both wires, you'll effectively have one very thick gauge wire.
I'm not so sure about that. If I understand correctly, the wires would be together forming a parallel circuit. Current will be divided between the two wires, but the amount in each lead will vary based on the resistance of the lead and its associated connectors. If you do end up running both leads, make sure all the connections are very clean.
roegs is offline
Old 11-21-2014, 10:35 PM
Goldenpony
Goldenpony's Avatar
I think I'm just going to use the new PA wire, not both. If something doesn't work, I'll do a re-think.
Old 11-22-2014, 09:27 AM
CMcNam
CMcNam's Avatar
That's what I did. Zero issues.
CMcNam is offline
Old 11-22-2014, 01:21 PM
Goldenpony
Goldenpony's Avatar
Default Tis" Done!
Installed PA Alternator and Power Wire Kit. Pretty easy install. Cleaned TB at the same time. Everything seems to be working fine. No strange noises. Now, to see if the CEL stays dark.
Thanks for all the advice.
Old 11-28-2014, 07:23 PM
Goldenpony
Goldenpony's Avatar
Default PA Alternator-Happy Dance
Well, it's been a week now with no CEL-I am convinced now it was definitely the alternator that was causing the P0340 code. No problems running the std. type pulley instead of the clutch. Pretty happy with the way it all worked out. The Power Wire kit was an easy install too.
Old 11-28-2014, 08:22 PM
jz78817
jz78817's Avatar
well, then, be sure about that.
jz78817 is offline
Old 11-29-2014, 07:19 AM
kingstrider
kingstrider's Avatar
The upgraded power wire should connect from the B+ terminal on the alternator to the battery. The OEM wire should be the thick cable on top of the passenger side fuel rail:
What air intake system is this?
kingstrider is offline
Old 11-29-2014, 09:31 AM
lenko
lenko's Avatar
Western Motor Sports. http://www.wmsracing.com/
lenko is offline
Old 11-29-2014, 09:50 AM
Chromeshadow
Chromeshadow's Avatar
I called both PA and American Muscle. PA said they recommend using both wires, American Muscle said to just use the performance wire. Great. That really clears things up.
AM is correct.
While it's unlikely that running two parallel wires, grounded at the same point on one end and connected to the same positive point on the other, will cause a problem, it's considered a huge error in design. By using two wires you form an antenna where the resonance frequency is unknown. In an entirely DC environment this is usually not a problem, but with all of the RF and pulsed currents in a new car, it is possible that you will create an intermittent problem that will be nearly impossible to track down.
Chromeshadow is offline
Quick Reply: New PA Alternator
