Sponsored by:
Sponsored by:
Electrical Problem on my 06 V6 mustang
Old 12-02-2014, 09:44 PM
Firefighter316
Firefighter316's Avatar
Default Electrical Problem on my 06 V6 mustang
I've had my mustang for almost 4 years now and I have never had a problem out of it before. About a month ago I was getting on the interstate and I got on it and all my light on the dashboard, headlights, radio, I mean everything went out and it made a loud buzzing noise. Since then every time you get on it and it reaches 70 all this happens over and over again. It's a very dangerous situation especially at night and I didn't know if anybody else has had this problem? Thanks for the help.
Firefighter316 is offline
Old 12-02-2014, 10:10 PM
Lethaldosage423
Lethaldosage423's Avatar
It's pretty common to get a water leak, it causes corrosion on electrical terminals and a module. Not sure of the specifics but I'm sure someone will chime in!
Lethaldosage423 is offline
Old 12-02-2014, 10:24 PM
Firefighter316
Great thanks so much!
Old 12-03-2014, 11:46 AM
rls82959
rls82959's Avatar
You may want to take a peek at the Smart Junction Box and check
the carpet for signs of water.
It's on the inside passenger side just in front on the door.
Water would leak in and get into the SJB and cause corrosion and all
types of electrical issues.
I'm not sure about the 06, but for 07 Ford put a adhesive piece of vinyl over
the SJB which diverted the water over the SJB door and down to the carpet.
rls82959 is offline
Old 12-07-2014, 07:08 AM
Nuke
Nuke's Avatar
Your issue sounds quite similar to the electrical gremlins caused by the infamous water leak but could also be associated with a weak battery and/or alternator (also another chronic issue which plagues the earlier S197's). There's a TSB for the water leak.
Nuke is offline
KingRando
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
2poor4u2
09-26-2015 11:08 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: Electrical Problem on my 06 V6 mustang
