Sponsored by:
Sponsored by:
bilstein hd struts and eibach pro kit springs
Old 01-03-2015, 08:05 PM
val916
val916's Avatar
Default bilstein hd struts and eibach pro kit springs
Looking to upgrade my suspension.could get a good deal on some bilstein hd struts and eibach pro kit springs was wondering how stiff the ride will be compared to stock suspension
val916 is offline
Old 01-04-2015, 01:07 PM
dusman59
dusman59's Avatar
I have the FRPP "P" springs with the Bilsteins. I like the quality and performance of a monotube dampener. Not sure how the springs compare to the Eibach but I have read in several places the are made by Eibach. The ride is firm but not harsh. I can't believe how much better the car handles. I went from the Brembo suspension which had nose dive when braking and plenty of bounce on certain road conditions. I used the GT500 mounts 180 degrees out and the alignment came in perfect. On the rear shocks you will need to reuse the top mount pin type rubber insulators. Make sure you cut down the rear bump stops as there is not much clearance after lowering. If you don't they will hit and make the rear more harsh than needed.
dusman59 is offline
Old 01-06-2015, 06:44 AM
05 Mustang
05 Mustang's Avatar
The Pro-Kit will ride a little bit stiffer compared to stock.
05 Mustang is offline
fcarpio
Suspension
11-16-2018 10:35 AM
PB Pod
Forum Issues and Feedback
09-17-2015 08:32 PM
09-16-2015 07:53 PM
robjh22
Suspension
09-08-2015 12:47 PM
RWHEELS
09-05-2015 03:42 PM
Quick Reply: bilstein hd struts and eibach pro kit springs
