Sponsored by:
Sponsored by:
Very rough idle then dies
Old 02-08-2015, 09:04 AM
ahouston22
ahouston22's Avatar
Default Very rough idle then dies
I have an 05 mustang gt I installed AFE CAI a few days back and the car ran fine. Went to crank it yesterday it would barely idle and cut off idle was so rough it sounded like it had a cam. It did it this maybe 4 times before it would idle properly. I'm fairly new to the mustangs could this be a dirty MAF sensor?
ahouston22 is offline
Old 02-08-2015, 11:44 AM
waykooljr
waykooljr's Avatar
Check that all connections are tight to make sure there are no air leaks.
Since it was running ok prior to the CAI I wouldn't think it'd be a dirty throttle body but doesn't hurt to check, it could need cleaning.
waykooljr is offline
Old 02-08-2015, 12:28 PM
ahouston22
ahouston22's Avatar
Ok thanks for the advice. I will take a look at the throttle body. Seems when I pull off the crank case line it starts perfectly fine
Old 02-09-2015, 02:25 AM
Dino Dino Bambino
Dino Dino Bambino's Avatar
A slightly dirty TB might not cause any problem with the stock intake/tune but a performance tune (with its more aggressive throttle response) will be much more sensitive to any dirt that's deposited between the blade and the TB bore.
Therefore I'd highly recommend cleaning it.
Dino Dino Bambino is offline
Old 02-09-2015, 09:46 AM
ahouston22
ahouston22's Avatar
The AFE didn't require a tune so Im kinda thinking it's actually going to need one. I will clean the throttle body before I do this just to be sure
Old 02-10-2015, 03:16 PM
Nuke
Nuke's Avatar
Quite a few No-tune-required CAI's run on the ragged edge of needing a tune but the additional airflow can simply cause issues if the TB was dirty even though it wasn't running poorly prior to the additional airflow. TB cleaning first, then see what's happening.
Nuke is offline
Old 02-10-2015, 04:41 PM
So_Cali
So_Cali's Avatar
Check that your MAF sensor is connected properly. I boneheadedly forgot to reconnect it once I had installed my CAI and had a similar issue.
Good luck
So_Cali is offline
Old 02-10-2015, 06:49 PM
ahouston22
ahouston22's Avatar
Thanks for all the help guys. What's the best to clean TB with?
Old 02-11-2015, 09:46 AM
waykooljr
waykooljr's Avatar
I used CRC Throttle Body & Air Intake Cleaner.
Old 02-12-2015, 10:20 AM
steveo555
steveo555's Avatar
Here is a small write up I did a while back on the subject.
https://mustangforums.com/forum/2005...with-pics.html
steveo555 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
guitarman376
09-30-2015 05:54 PM
Quick Reply: Very rough idle then dies
