Sponsored by:
Sponsored by:
best engine bay clean method. both with water and without.
Old 02-17-2015, 08:36 AM
Pr0cl1v1ty
Pr0cl1v1ty's Avatar
Originally Posted by Siber Express
Scrubbing Bubbles Bathroom Cleaner, spray it down on a cold engine and lightly rinse. Waterless after it is clean I use Meguiar's Detailer mist and 2 rags. If it is dirtier than Meguiars I use the rag I wipe the wheels of with first and the the Detailers mist.
Wax it with Turtle Wax Ice, makes it a lot easier to clean the next time.
Easier wash next time? MUST WAX EVERYTHING...
Haha but seriously it does help a substantial amount and makes the car beautiful in the process
Pr0cl1v1ty is offline
Old 02-17-2015, 12:06 PM
cema93
cema93's Avatar
I took a spray bottle and filled it with 1 part simple green and 3 parts water. I wrapped and bagged up the alternator, air filter, fuse box, and battery ( u may not have to but i DO). i then set the garden hose nozzle on shower and gave the engine a couple shorts squirts. i then sprayed everything down with my simple green mixture and let sit for about 10 min. then lightly rinsed and dried.
also, i heard it helps to have ur engine a little warm ( NOT A HOT ENGINE) due to the idea of spraying the mixture on the engine and closing the hood, allowing the spray to "cook" in there. then rinse and dry.
cema93 is offline
Old 02-17-2015, 07:42 PM
potman
potman's Avatar
I just spray mine off at the car wash and wipe it down.....
Been doing it for years, My 99' Tahoe engine bay looks like new.
potman is offline
Old 02-18-2015, 05:36 PM
Cobra4me
Cobra4me's Avatar
I use simple green diluted also. Wrap up the air box and fuse box. I will add though I take a electric leaf blower to dry to engine
Cobra4me is offline
Old 02-19-2015, 10:59 AM
Nuke
Nuke's Avatar
I've used my pressure washer gingerly with only water but then again, my engines haven't been so bad that I've had to use anything stronger. When I was a kid and the typical domestic engine was hidden under a 1/2" thick layer of grime, people swore by a kerosene bath. My pressure washer allows me to induce a cleaner of some type and I'd consider that or some other type of degreaser that's more environmentally friendly than kerosene.
Nuke is offline
Old 02-20-2015, 01:46 AM
kcobra
kcobra's Avatar
I just wipe the engine down after every time I wash the car. Stays clean and beautiful.
kcobra is offline
Old 02-20-2015, 03:51 PM
Roy_R
Roy_R's Avatar
Simple Green is corrosive and will react with bare aluminium causing hydrogen embrittlement...don't do it. They do make an aircraft cleaner, that is safe to use on engines!
http://industrial.simplegreen.com/in...ts_extreme.php
I use Orange clean, works just as well....
Roy_R is offline
ShaneB26154
35
03-04-2021 04:05 AM
eastexsteve
3.7L V6 Technical Discussions
12-04-2015 05:41 AM
MusicCity615
09-27-2015 12:53 AM
Aggiebq86
09-04-2015 12:20 PM
Quick Reply: best engine bay clean method. both with water and without.
