Sponsored by:
Sponsored by:
Help! "Check Charging Systems" keeps popping up.
Old 04-13-2015, 08:36 AM
Superman_20
Superman_20's Avatar
Unhappy Help! "Check Charging Systems" keeps popping up.
My 05 Mustang GT with Shaker system one day had the "Check Charging Systems" light pop up so I checked the alternator and it turns out it was going bad. I replaced it with a brand new stock alternator. I also replaced the battery as well.
After about 500-600 miles or so the "Check Charging Systems" light popped up and it didn't happen anymore. Now it just happens more and more often. It can happen multiple times during a drive. I just drove today 40 miles and I counted 9 times it came up with that annoying ding and then would stop. The radio is almost always turned off as I don't listen to it much.
The car was taken to a mechanic and the alternator and battery were checked and everything seemed fine. The battery terminals were tightened. I don't know what else I could do.
Has anyone experienced this before? It tends to happen more I feel at idle but it is hard to tell because it is now a regular part of driving my car. At any moment I hear the ding and see the light saying "Check Charging Systems".
Superman_20 is offline
Old 04-14-2015, 11:23 AM
Superman_20
Bump, anyone had this problem?
Old 04-14-2015, 10:48 PM
WJBertrand
WJBertrand's Avatar
Have you checked the accessory belt and tensioner? Maybe the belt is loose or slipping. What about the other ends of the battery cables, the negative to the block and the positive to the starter solenoid? Are they tight clean and corrosion free? What about the condition of the cables themselves?
WJBertrand is offline
Old 04-14-2015, 11:18 PM
jwog666
jwog666's Avatar
could be a pcm issue, the pcm controls the alternator field. better diag is needed
jwog666 is offline
Old 04-24-2015, 07:29 PM
degeze
degeze's Avatar
Years ago my car was constantly reading "Check Charging System" on the OSD with no apparent interruption in car operation. I replaced the alternator with a new factory replacement but continued to have the same issue. Finally, I went with the PA Performance (130 Amp) alternator with the Premium Power Wire Kit and have not had any issues since. This may not be your problem but I would like to think it was a combination of the wire along with the alternator that fixed mine.
degeze is offline
Old 04-26-2015, 10:51 AM
Nuke
Nuke's Avatar
If you replaced the oe alternator with another motorcraft, then I'd be wary. The motorcraft replacements seem to have a poor track record as well as the oe units.
Nuke is offline
Old 04-26-2015, 09:01 PM
Art161
Art161's Avatar
But if you bought the Motorcraft alternator from a Ford dealer and had them install it, I think it's guaranteed (parts and labor) for 2 years.
Art161 is offline
Old 04-26-2015, 11:19 PM
jwog666
jwog666's Avatar
correct^^^
jwog666 is offline
Old 05-26-2015, 03:36 PM
arquick
arquick's Avatar
So here is the scoop guys. I have a 2005 mustang gt with 50k miles. I get the battery light and check charging system after the car is running for a couple minutes and it stays on. The alternator checked out good and so did the battery. The alternator is a motor craft and the battery is a red optima. Im thinking there is a short but I do not know where. Any help would be great.
arquick is offline
Old 05-27-2015, 07:23 AM
9050scott
9050scott's Avatar
Check to see if corrosion has crept up the cable under the shielding.
9050scott is offline
Quick Reply: Help! "Check Charging Systems" keeps popping up.
