Sponsored by:
Sponsored by:
No start, 2006 V6
Old 06-13-2015, 06:04 PM
meador
meador's Avatar
Default No start, 2006 V6
Hi all,
Our 2006 V6 mustang will push start (and then run fine) but won't crank start.
Battery voltage at rest is fine, battery and starter cables appear fine, lights/radio work, and I removed the starter and Autozone said it tested good.
Are there other things I can check myself (ignition switch, clutch position sensor, etc)? Don't know much about automechanics, but I can use a wrench, multimeter, etc.
Thanks
meador is offline
Old 06-13-2015, 08:23 PM
bl817
bl817's Avatar
check your ground cables. ground to body, engine to body. good luck
bl817 is offline
Old 06-14-2015, 07:29 AM
meador
meador's Avatar
Well, when I put the starter back on, it started right up. Maybe the ground or one of the cables was loose, but I don't think so. I am afraid the problem is just waiting to happen again; we'll see.
At least my daughter learned how to push start a car!
meador is offline
Nick Oliver
10-17-2018 04:22 AM
PullTab
10-30-2015 08:46 AM
Mustangmalo
09-06-2015 05:22 PM
09-03-2015 07:14 PM
Quick Reply: No start, 2006 V6
