Sponsored by:
Sponsored by:
12v source under hood, need help with headlight wiring
Old 06-18-2015, 09:03 AM
dseg
dseg's Avatar
Originally Posted by jwog666
they must have messed up the pin #s in the diagram (shakes head lol), those are still the correct colors.
Thanks, where did you get your information? Have you done this before?
So "Relay-Park Lamp" is the horizontal double light bars? Like this
dseg is offline
Old 06-18-2015, 09:25 AM
jwog666
jwog666's Avatar
im a ford tech, so i just looked in the service manual wiring diagrams, that pic is for an aftermarket headlamp. if you wire it as described it will come on with the park/marker lamps. if you want to see with what just turn on your park lamps and check it out
jwog666 is offline
Old 06-18-2015, 12:36 PM
dseg
dseg's Avatar
I have lights that are on even when I don't put the "park lamps" on.
Are those considered "running lights?"
Those are the wires I want to tap into. So that is still the white/violet and grey/black?
Thanks for the responses, I really appreciate it.
dseg is offline
Old 06-18-2015, 12:41 PM
jwog666
jwog666's Avatar
those lights also come on when the door is opened, the car is unlocked, etc. they arent referred to as "running lights" by ford, just park lamps, on the factory diagram they also have what they call cornering lamps, but they are led and will most likely not like the added draw, white and violet for + and grey and black for neg.
jwog666 is offline
Old 06-18-2015, 01:59 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Yeah, don't draw from any circuit that runs LED lights. What you will get is either a diming/brightening of the LED's (they are very voltage sensitive) or a strobe effect. the only way to counter those issues is to then get a 12V voltage regulator in-line for the LED lights. At that point you are overcomplicating things.
Derf00 is offline
StalkerGT
11-28-2015 03:09 PM
11-18-2015 01:34 PM
zachary1988
09-18-2015 11:17 PM
unit91
09-15-2015 09:53 AM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: 12v source under hood, need help with headlight wiring
