hood repainting requiring entire front end/car to be repainted?
#53
aluminum doesn't rust. but it is a very reactive metal. the thing that keeps it bright and shiny is the fact that it's so reactive; the instant you expose bare aluminum to air it forms a thin coating of (transparent) aluminum oxide on the surface, a process called passivation.
on the other hand, if it's touching a dissimilar metal (like iron,) that reactivity means it will corrode fast if it gets wet. the general assumption on these Mustang hoods is that the seams were contaminated by iron/steel, and as water/salt seeps in there it kicks off galvanic corrosion.
#55
#56
http://www.popularmechanics.com/cars...-150-16682803/
they tested them in some pretty harsh places before launch, but we will see how they work in the salt belt
#57
I believe the Mustang's hoods have been made by an external supplier, while Ford stamps the F-150 body panels themselves at Dearborn Stamping. they talked at length about what they did to "decontaminate" the stamping plant and body shop prior to launching the truck.
#58
New expeditions, explorers and also edges have hood problems that I've seen...
#60
Ford should have made a deal with an aftermarket fiberglass hood company and gave those of us who have had the issue, a new fiberglass hood. When I got mine fixed, the rep told me that the only cure would be a fiberglass hood. Another Ford aluminum hood is not the answer unless they totally revamped the way they were made.
