Sponsored by:
Sponsored by:
Fuel Pressure Sensor 2005 gt
Old 07-14-2015, 09:38 AM
Su Roberts
Su Roberts's Avatar
Default Fuel Pressure Sensor 2005 gt
I got a code of 0193 saying my fuel pressure sensor needs to be replaced. Replaced it no problem very easy to do. My check engine light did not go off. Is there something I am missing? Any suggestions would be great. thanks
Su Roberts is offline
Old 07-14-2015, 10:09 AM
Moderator
JimC's Avatar
You need to clear the code - or continue driving until it re-registers. Do you have the SCT or Predator to read the code or did you go to one of the auto stores to have them read it? If you have your own handheld you can clear the code yourself.
I would clear the code (and double check to see if you have a new code for the CEL). That will tell you if you've actually taken care of the problem with the new sensor. If it didn't, within a short time your CEL will trip again and you will know that something else is needed that way.
JimC is offline
Old 07-14-2015, 04:36 PM
Su Roberts
Su Roberts's Avatar
I have car md that gave me the code and problem. How long until it resets itself?
Old 07-14-2015, 11:17 PM
jwog666
jwog666's Avatar
hard to say, that is determined by ford, and isnt really published, sometimes a few drive cycles, sometimes alot of drive cycles
jwog666 is offline
Old 07-21-2015, 07:03 PM
kenthicken
kenthicken's Avatar
It will be a few drive cycles, or about 100 miles or so.
kenthicken is offline
Old 07-22-2015, 07:17 PM
algregory
algregory's Avatar
I have an '05 GT that used to reside in California with me till '07. A couple of years ago I got a engine check light on it. The explanation was that the fuel pump's return line pressure was too low, something like that anyway. They put in a new fuel pump. Back in the day people used to complain about problems with their cars after a long steady-state drive and slowing down and re-accelerating. A lurch, an un-smooth transition or something. Since then my car runs better and feels stronger, doesn't have those issues which were rare, but happened on occasion.
A year, maybe near two, later the light came on again. Ford blamed it on the FP again, I told them they had already replaced the pump, they went back to the drawing board. I had a Granatelli intake with a "chip" of its own at the time. They said that the Granatelli was not allowing the code to reset, however that stuff works. They said they unplugged Granatelli and that allowed reset to happen.
More time passed, the light returned. I figured I knew what it was. I had talked to someone that had used intake and a "tuner" one day, I had kept his number. He still had it. Installed, check light went away, sorry I hadn't bought that thing years ago, MUCH BETTER than Granatelli.
FWIW, i post this because you have an '05 GT and a fuel pump issue.
algregory is offline
Old 08-04-2015, 02:44 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Any Device that can read the code should have a 'Code Clear' function. Double check that.
If not disconnect the battery for about 20 minutes. That will clear the codes. If you only unhook it for a few minutes, it will not erase it.
Derf00 is offline
Jb145700
08-21-2022 06:37 AM
StalkerGT
09-25-2015 02:41 PM
TfcCDR
09-14-2015 12:08 PM
94stangnewbe
V6 General Discussion
09-07-2015 07:39 PM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: Fuel Pressure Sensor 2005 gt
