Sponsored by:
Sponsored by:
Limp mode.... 07 mustang v6
Old 07-25-2015, 06:25 PM
kritllsj
kritllsj's Avatar
Default Limp mode.... 07 mustang v6
So my car battery died.... and i didn't know this since all i had was my classic and it was easier... but i unplugged both the negative and positive when my v6 battery died so now computer reset and might of lost all it's memory... so now it doesn't go over 1k RPM.... scanned it and all the code was from the throttle... 11 of them... should i replaced the throttle body or.... sorry new to this forum... And yes i tried every method so the computer can relearn but no luck HELP plwwzz
kritllsj is offline
Old 07-26-2015, 10:49 AM
kenthicken
kenthicken's Avatar
Computer reset, as you said, so it does have to "learn" again, which can take some time - and the car will "limp" around for a while (mine always likes to stall). I would clear the codes first, clean out the throttle body, drive the car around a bit, and see if it throws them again.
If it keeps throwing codes, then look at the throttle position sensor (before replacing the entire throttle body). Good luck.
kenthicken is offline
Old 07-26-2015, 06:40 PM
kritllsj
kritllsj's Avatar
Already tried doing all of that but it seems to not want to respond... or relearn... So i tried something... I while the engine is running i pulled to plug for the throttle body sensor and after that the throttle started responding but not quite... so i'm going to try to replace just the tps cause i don't want to buy the whole thing and see if that works.
kritllsj is offline
Old 07-26-2015, 08:54 PM
Moderator
JimC's Avatar
What codes are you getting?
JimC is offline
Old 07-27-2015, 02:18 AM
kritllsj
kritllsj's Avatar
P0120,0125,1235 or somethin like that... kinda late to be checking and got work tomorrow but those are the codes that pops up, i might have to change the tps.... but like i said though while the engine was running... i unplug the tps and the engine rammed up... idk if it is the tps or the whole throttle body... it could even be that i have low gas hahaha. I mean before my battery died, everything and i mean everything was working perfectly, then i accidently unplugged the whole battery without keeping it alive.... so i bought a new battery and all this crap happens... a wrench light/engine like... so all this code i got is mostly from the throttle body though...
kritllsj is offline
djbigskrilla
09-20-2022 01:04 AM
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
chain
08-17-2015 08:52 AM
daytooday
08-11-2015 09:22 AM
Quick Reply: Limp mode.... 07 mustang v6
