Sponsored by:
Sponsored by:
Dirty Throttle Body? Idle / stalling issues
Old 08-08-2015, 08:38 AM
stanngg
stanngg's Avatar
Default Dirty Throttle Body? Idle / stalling issues
Thinking my throttle body may be dirty. Motor runs fine throw the gears but idle dips real low and sometimes stalls when stopped. (Clutch pushed in) Hoping cleaning the throttle body will solve problem. Anyone have this issue? Also heard that certain solvents can damage the protective coating....so need to find the right cleaner...
stanngg is offline
Old 08-08-2015, 03:06 PM
waykooljr
waykooljr's Avatar
This issue has been experienced by many, including myself. You're on the right track cleaning the throttle body. I used CRC Throttle Body & Air Intake Cleaner which is safe for coated throttle bodies.
waykooljr is offline
Old 08-08-2015, 04:03 PM
stanngg
stanngg's Avatar
Thanks bro.... gonna go get some now! Autozone carry it? Do I need to pull the throttle body off? Or can you just spray that stuff in there.
stanngg is offline
Old 08-09-2015, 12:37 AM
808muscle
808muscle's Avatar
I just spray in there myself
808muscle is offline
Old 08-09-2015, 09:50 PM
stanngg
stanngg's Avatar
Thanks for the advice guys. Cleaned the throttle body and problem solved!
stanngg is offline
Old 08-10-2015, 06:17 AM
Dino Dino Bambino
Dino Dino Bambino's Avatar
It's probably a good idea to make the cleaning of the throttle body a routine item at each service interval.
Dino Dino Bambino is offline
Old 08-10-2015, 11:15 PM
stanngg
stanngg's Avatar
Agreed!
stanngg is offline
Old 08-11-2015, 09:25 PM
DRAGUL
DRAGUL's Avatar
If you don't have a catch can get one. I installed one on my 05, and I could not believe the amount of oil it catches and keeps out of the intake.
DRAGUL is offline
Old 08-12-2015, 01:57 AM
Dino Dino Bambino
I have breather filters on both valve covers and clean them every 6 months.
The passenger side PCV port on the CAI pipe and the driver's side PCV port on the intake manifold are capped off so no oil vapors can enter the intake system.
Old 08-12-2015, 02:26 PM
stanngg
stanngg's Avatar
Where do I get the catch? Autozone?
stanngg is offline
Quick Reply: Dirty Throttle Body? Idle / stalling issues
