Sponsored by:
Sponsored by:
unstable 06Mustang V6 Base
Old 08-27-2015, 10:08 PM
Careless00045
Careless00045's Avatar
Default unstable 06Mustang V6 Base
Hello,
The car is unstable when i go over 70MPH ! its kinda wondering! i have to hold the steering wheel with both hands trying to keep it inside my lane on the highway !
Though the steering wheel or the car are NOT shaking at all.
Whats wrong with her now?!!
Model: 2006 Mustang V6 Base.
Thanx
Careless00045 is offline
Old 08-28-2015, 07:31 AM
bl817
bl817's Avatar
I would point you towards the lower tie rod ends or ball joints. get the front end up on ramps if you can and pull on the tie rods and see if there is any play. if you can, remove the wheels and see if you can move the rotor/hub assembly side to side or top to bottom. worn tie rod ends will allow movement on the axis of the hub (a line equal to the strut, top to bottom). worn ball joints are harder to pinpoint until you take the load of the car off them. it could also be worn front lower control arm hydro bushings. if your not so inclined to check the parts yourself, take it to a mechanic/shop you trust. good luck
bl817 is offline
Old 08-29-2015, 10:44 AM
SteveDwsn
SteveDwsn's Avatar
I bet you are going to find tire wear too. Take it to a shop and have it checked out. BL817 is right, it is probably tie rod ends. In any case it will require an alignment.
SteveDwsn is offline
yurizx6r
05-11-2015 08:46 AM
Boss 246
03-06-2012 11:37 AM
simpkins_44
03-01-2011 12:32 PM
HC_CrAzYHoRsE
11-02-2006 08:21 PM
88BlueGT
10-18-2006 05:24 PM
Quick Reply: unstable 06Mustang V6 Base
