Ticking coming from 4.6L. What could it be?
Ive got a ticking sound coming from my engine and I don't know what could be causing it. It sounds like its coming from right around the intake manifold.
I tired to get a video but Im not sure how much it will help. I can hear it very clearly at low RPM when accelerating but it goes away (or at least i cant hear it) at speed. Any ideas on what to check? I ran some Seafoam through my oil last oil change to try and clean things out and I have ran some through my gas but nothing has made a difference. Other than the noise, everything seems normal.
I did notice one of the bolts on my header was backed off a little. Could it be an exhaust leak?
Advice??
Advice??
If it is a valve lifter, what can i do to fix it?
If it is a lifter, maybe a heavier weight oil. I run 5W 50 in mine (Motorcraft Brand)
