Sponsored by:
Sponsored by:
Control Arm Questions
Old 10-20-2015, 06:03 PM
dlazrael
dlazrael's Avatar
Can you just order OEM 09+ GT500 from rock auto and use those?
dlazrael is offline
Old 10-21-2015, 06:33 AM
LordRipberger
LordRipberger's Avatar
I didn't seem them on there. At least they didn't indicate they were on there. I guess I could check under other years.
LordRipberger is offline
Old 10-22-2015, 02:41 PM
dlazrael
dlazrael's Avatar
$172/per under 09 GT500 from Motorcraft
dlazrael is offline
Old 10-23-2015, 11:57 AM
LordRipberger
hahah, I hadn't looked under 2009 until after I posted and then never corrected it. Thanks. Sill almost 400 for the two of them when my stock ones lasted almost 10 years. And only one needs replaced.
Old 10-25-2015, 06:50 AM
MEK
MEK's Avatar
I purchased a set (GT500) from Tasca a couple years ago for ~$200, they have gone up a little, but still a lot cheaper than $400.
http://www.tascaparts.com/control-ar...rade/m-3075-e/
MEK is offline
Old 10-26-2015, 06:35 AM
LordRipberger
And we are sure the GT and GT500 will fit a V6? I am not sure of what, if any, the charges are between the models.
And, the listing says GT, not GT500. How do we know these are not just the stock GT ones?
Old 10-26-2015, 06:53 AM
Norm Peterson
Norm Peterson's Avatar
From the Description. It fits the GT but was OE on the GT500.
Product Description
Fits 2005-2010 Mustang GT built on or before 8/3/09 with 18mm ball joint shaft
Original equipment on 2007-2009 Shelby GT500
Increased strength ball joints
Kit contains 1 RH and 1 LH lower control arm assembly
NOTE:Some factory fasteners are one time use. Please reference a Ford service manual for reuse information and correct torque specifications.
The ball joint item is the important one.
Norm
Norm Peterson is offline
Old 10-26-2015, 06:54 AM
MEK
MEK's Avatar
The listing says GT Upgrade. Also:
"Fits 2005-2010 Mustang GT built on or before 8/3/09 with 18mm ball joint shaft
Kit contains 1 RH and 1 LH lower control arm assembly"
Has correct part number listed: M-3075-E
From another site, same part number:
"Fits 2005-2009 V6 built on or before 2/26/09 with 18mm ball joint shaft.
Fits 2005-2010 GT built on or before 8/3/09 with 18mm ball joint shaft.
Fits original 2007-2009 GT500."
Someone correct me if I am wrong, but I believe the V6 & GT use the same control arms stock. These work on my car and I have a 2007 V6.
MEK is offline
Old 10-26-2015, 07:19 AM
LordRipberger
Well my mustang is before 2/26/09, but are they starting there was an option to have something other than an 18mm ball joint shaft, or are they just providing that information?
I guess I could call them later today, but I would like someone here to confirm.
Old 10-26-2015, 07:35 AM
LordRipberger
RockAuto has the same part numbers CK (or RK) 80727 and CK80726 for the control arms for 2006 V6/GT and 2009 GT/GT500. So I think we are getting closer to assume it fits both cars.
Quick Reply: Control Arm Questions
