Strut to spindle bolts - MustangForums.com
Go Back   MustangForums.com > Ford Mustang Tech > 2005-2014 Mustangs
Search
Old 10-28-2015, 01:10 PM   #1
LordRipberger
LordRipberger's Avatar
Vehicle: 2006 V6 Mustang
Default Strut to spindle bolts
Hey guys,
I am going to replace my LCAs and have a question about the Strut to Spindle bolts.
I was talking with Norm and it was suggested that I replace these bolts as they are labeled "one time use". However, I have read on multiple other forums while trying to find them cheaper, that most people just reuse them. Some use locktite and some do not. So I want to know what you think, reuse and locktite or not. It will cost another 50 to get these so if I can avoid the cost, I would be alright with that. My mustang has 112k miles on it and I have never replaced them or done any work on the front except cosmetic and tie-rod replacements.
Thank you for your help.
LordRipberger is offline   Reply With Quote
Old 10-28-2015, 05:45 PM   #2
Goldenpony
Goldenpony's Avatar
I would assume as long as you use a good thread locker like Locktite or Vibratite you'll be fine.
__________________
2006 Premium GT Convertible
Screaming Yellow, Black Top
Michelin Pilot Super Sport tires
18" "Fanblade Wheels"
CORSA Performance exhaust
Brenspeed 87 octane performance tune
MGW Shifter
Goldenpony is offline   Reply With Quote
Old 10-29-2015, 11:44 AM   #3
LordRipberger
What is the point of locktite? To prevent vibrations wiggling the nut loose?
Old 10-29-2015, 06:57 PM   #4
Goldenpony
Goldenpony's Avatar
Quote:
Yup, to keep the nut from backing off the bolt-this would be a bad thing.
__________________
MGW Shifter
Old 10-30-2015, 07:30 AM   #5
LordRipberger
Quote:
Indeed.
Old 11-03-2015, 05:16 PM   #6
flash_xx
flash_xx's Avatar
Vehicle: 2007 Ford Mustang GT
chperezn
Get the new strut to spindle bolts with the fine pitch thread. They are more robust than the original ones. No sense in having an accident over a 20 dollar part
__________________
flash_xx is offline   Reply With Quote
Old 11-04-2015, 09:53 AM   #7
PNYXPRESS
PNYXPRESS's Avatar
Vehicle: early '00, '08, '91, '96
Just get a similar sized grade-8 bolt and a nylon lock nut. no need to spend $20-50 on a couple of bolts because they say ford on them.
__________________
1991 2.3L I4
1996 3.8L V6
2000 3.8L V6
2008 4.6L V8
PNYXPRESS is offline   Reply With Quote
Similar Threads
replacing motor mounts at home Drastang 4.6L (1996-2004 Modular) Mustang 4 11-05-2015 03:04 PM
New member with a question MikeGTcs2011 New Member Area 6 10-30-2015 12:29 AM
Speedometer Cable Gear Replacement Pyrate Dave 5.0L (1979-1995) Mustang 2 10-27-2015 07:28 PM
question about fog lights on 01 gt lanej2 4.6L (1996-2004 Modular) Mustang 2 10-27-2015 11:09 AM
5.4 swap questions Ghostmustang Motor Swap Section 1 10-25-2015 06:38 AM
