Sponsored by:
Sponsored by:
Anyone running 10" 305/35-19? Clearance questions
Old 11-01-2015, 11:43 PM
JayBeStangs94
JayBeStangs94's Avatar
Default Anyone running 10" 305/35-19? Clearance questions
Hello my mustang friends, I'm upgrading tires for a better fit on my 13 mustang, currently with a 10" rim and 285/35-19 tires (in the rear).
I'd like to upgrade the width by 20mm to a 305/35-19; question is will I clear with a 2.5" drop (coils) in the rear?
Here's a current picture with the
setup.
Offset +48
JayBeStangs94 is offline
Old 11-01-2015, 11:46 PM
JayBeStangs94
Originally Posted by JayBeStangs94
Hello my mustang friends, I'm upgrading tires for a better fit on my 13 mustang, currently with a 10" rim and 285/35-19 tires.
285 setup.
Offset +48
Thanks for all your help!
Old 11-02-2015, 12:47 AM
AK_Kayaker
AK_Kayaker's Avatar
I think most tire manufacturers want you to run at least a 10.5" with 305's.
On the forums some will say they will work, while others will say they are too narrow, I say best to go with what ever the tire maker recommends.
AK_Kayaker is offline
Old 11-02-2015, 06:47 AM
Norm Peterson
Norm Peterson's Avatar
I'm pretty sure that most mfrs and the T&RA consider a 10" wide rim to be the minimum for 305/35's (in any wheel diameter). Keep in mind that relatively narrow wheels (like this proposed setup) will allow greater amounts of lateral tire distortion while cornering.
The "measuring width" for 305/35's is 11". Just saying . . .
Norm
Norm Peterson is offline
Old 11-02-2015, 11:41 AM
Andy13186
Andy13186's Avatar
It would be very close and id bet youd rub with that much lowering. It also depends on the wheel offset. I wouldnt risk it though if you want to stay lowered stick with 295s (those SHOULD fit, but still depends on wheel offset). I had to raise the rear of my car back to stock height to fit the 315's.
305s did fit fine with steeda sport springs i believe, if i remember correctly.
Andy13186 is offline
Old 11-02-2015, 09:38 PM
JayBeStangs94
I would definitely do the 295 if the cheaper tire brands would offer that size! Preferably the nitto invo or the nt05
Old 11-02-2015, 09:42 PM
JayBeStangs94
Norm
Thanks, Norm. Can you clear up the idea about tire distortion for cornering on this narrow rim? I'm now picturing the excess tire distorting upon corners; I never took this into perspective. Would it not benefit me running a wide tire in relation to my rear end being more 'planted' around corners? Or would it do more harm than good?
Old 11-03-2015, 08:33 AM
Norm Peterson
Better a picture than a thousand words . . . from Paul Van Valkenburgh's "Race Car Engineering & Mechanics". Kind of extreme, but all tires behave similarly (just to different extents depending on lateral g's, wheel widths, tire construction, etc., etc.).
Norm
Attached Thumbnails Anyone running 10" 305/35-19? Clearance questions-lateral-tire-distortions-web1.jpg
Old 11-03-2015, 01:22 PM
JayBeStangs94
Norm
Norm, I'm sure you wouldn't recommend spacers either, after google searching your name and 'wheel spacers.' I am a big fan of my handling, looks like I should go with a wider rim if I want a wider tire.
So would you recommend just sticking to my original setup, the 285/35 on the 10" rim?
Old 11-03-2015, 06:53 PM
Norm Peterson
Yes.
I'm not against the use of very thin spacers to solve a minor rub - the right front of my car gets an 0.025" spacer when the 18x11's go on for that very reason.
Yes. You should be able to make that work at both ends of the car and still be rotate-able front to rear.
Norm
Quick Reply: Anyone running 10" 305/35-19? Clearance questions
