Sponsored by:
Sponsored by:
A little problem
Old 11-28-2015, 10:24 PM
avengercap67500
avengercap67500's Avatar
Default A little problem
Since it's been raining too out the car for a drive noticed that there was water in the passenger side have a idea just seeing if anyone else had this water leak problem
avengercap67500 is offline
Old 11-29-2015, 05:15 AM
Murphdog
Murphdog's Avatar
This might be helpful.
Murphdog is offline
Old 11-29-2015, 08:02 AM
rls82959
rls82959's Avatar
Yep, check those drain plugs first.
Take a look at the water leak technical service bulletin. TSB.
I had a water leak and it was a damaged cowl grommet, the outside
grommet on the passenger side. Probably damaged by me when replacing
cabin air filter.
Hopefully it's just a drain or grommet issue. Good luck.
rls82959 is offline
Old 11-30-2015, 01:29 PM
Nuke
Nuke's Avatar
cabin air filter.
Nuke is offline
Old 11-30-2015, 08:34 PM
jz
jz's Avatar
Very common issue. Follow the posted info (TSB) and you should be fine.
jz is offline
Old 12-07-2015, 08:05 PM
avengercap67500
Thanks guys it's been pretty calm weather wise but appreciat the love!! ... that should help me out a lot! ��
MADSCOTSMAN
12-08-2015 11:13 AM
Panthermom
11-25-2015 09:16 PM
Urambo Tauro
11-25-2015 03:02 PM
Mr. D
11-25-2015 09:34 AM
demas
11-23-2015 04:12 PM
Quick Reply: A little problem
