Sponsored by:
Sponsored by:
Using cruise control buttons for radio volume
Old 02-23-2016, 12:31 PM
  #31
evillela2001
evillela2001's Avatar
Originally Posted by kevsgt
You mean disconnect that connector and don't reuse that connector at all? I'm not sure what the other wires in that connector do, so I'd be afraid to not reconnect them.
Good point. What about disconnecting the connector on the switch end and running the the 2 or 3 wires needs using those LED connectors to the spare clockspring connector then using the other end in the picture above. I hope this makes sense.
evillela2001 is offline
Old 02-23-2016, 05:49 PM
  #32
kevsgt
kevsgt's Avatar
Sorry, not making sense. Spare clockspring connector?
I will probably just splice into the 2 wires about an inch away from the connector in the picture.
kevsgt is offline
Old 02-23-2016, 09:20 PM
  #33
kevsgt
kevsgt's Avatar
Originally Posted by edwin108
The adapter I used (Pac SWI-PS) allows you to splice in additional resistors to make the buttons work.
The SWI-RC has instructions specific to each vehicle, pertaining to what wires to use, what wire loop to cut, and whether or not to add resistors. However, since my car isn't listed (since steering wheel doesn't have audio buttons), I am not sure how to handle that. I've contacted PAC but they seem unwilling to help so far.
kevsgt is offline
Old 02-24-2016, 09:14 AM
  #34
evillela2001
You're probably going to have to find out what resistance the buttons put out for a car that came equipped with controls (2010+ I believe) and then try and match those values to your setup.
Old 02-24-2016, 01:25 PM
  #35
edwin108
edwin108's Avatar
I connected resistors via trial and error until I got the buttons to work in my F150.
edwin108 is offline
Old 03-07-2017, 11:38 PM
  #36
Screech511
Screech511's Avatar
Default Steering wheel controls
I did this in my '05 F150. I used a wiring diagram to find the two wires for the switches and cut them. Then I connected one to ground and the other to a steering wheel control adapter (Pac SWI-PS). The adapter I used works with a Pioneer AVH-X3500BHS; make sure the one you buy is compatible with your head unit.
after looking high and low im happy to find someone who has sucessfully accomplished this, i am getting ready to attempt this as well but am having a lot of trouble figuring out what wires i would need to cut and connect from the steering wheel to the module. If you could be of assistance i would really appreciate it.
Screech511 is offline
LordRipberger
10-28-2015 11:53 AM
LordRipberger
10-17-2015 10:18 AM
mdj89
10-14-2015 08:10 AM
damex
10-09-2015 01:17 PM
mustangheaven
10-07-2015 10:23 AM
Quick Reply: Using cruise control buttons for radio volume
