Sponsored by:
Sponsored by:
clunking noise/manuel
Old 03-01-2016, 12:40 PM
Rozay_palm
Rozay_palm's Avatar
Default clunking noise/manuel
alright guys having a tough issue finding out this issue, have a 2006 gt with about 60k. clunking noise while feathering the accel. on and off the throttle. as soon as i touch the gas and let go there is a constant clunk. im starting to think its in the clutch/tranny just because ive replaced everything i thought was the issue...rear lower control arms and upper/ with a new bushing. i replaced the drive line as well. and i also have motor mounts i need to put in. then the most recent thing were my spider gears because they had tons of wear and play, and i replaced those with OEM ford stuff. anyways, becoming very annoying.
anything helps, thanks
Rozay_palm is offline
Old 03-01-2016, 12:55 PM
jz78817
jz78817's Avatar
I think Manuel is stuck in the trunk and banging on the lid. Maybe you should let him out.
jz78817 is offline
Old 03-02-2016, 06:02 AM
JJHoover
JJHoover's Avatar
how about the transmission mount, it may be broken
JJHoover is offline
Old 03-02-2016, 09:11 AM
Urambo Tauro
Urambo Tauro's Avatar
If you already know that the engine mounts need replacing, and you're looking for the source of a clunking sound...
I think even Manuel would agree that you're on the right track.
Urambo Tauro is offline
Old 03-02-2016, 07:59 PM
Rozay_palm
Rozay_palm's Avatar
haha cant believe i didnt catch that. well i got the motor mounts because the car is getting old and most things are original. i dont believe its the issue mostly because i can hear the clunk in the clutch/trans area. and i have replaced the trans mount and bracket. but i am going to replace the motor mounts just to cross it off the list
Old 03-02-2016, 08:41 PM
Nuke
Nuke's Avatar
The stock driveline in the manual tranny vehicles is very clunky. Other than checking your u-joints, its (supposedly) normal.
Nuke is offline
Old 03-05-2016, 01:24 AM
jrzyboy76
jrzyboy76's Avatar
Get an aluminum one piece driveshaft and the clunking will go away.
jrzyboy76 is offline
Old 03-06-2016, 04:36 PM
loots06
loots06's Avatar
This^^^^its very common.
loots06 is offline
Old 03-07-2016, 07:52 AM
flash_xx
flash_xx's Avatar
If you have an adjustable BMR panhard with rod ends, that's where the noise is coming from. I have to keep fixing mine because it rotates and starts hitting the chassis. Very annoying.
flash_xx is offline
Zacharyzb1997
02-03-2016 01:25 PM
VTXCO
01-15-2016 12:10 PM
duffman668
01-02-2016 09:19 AM
tkfozli
12-30-2015 04:34 PM
aab434
12-07-2015 05:22 PM
Quick Reply: clunking noise/manuel
