Noisy Interior?
Not sure if this helps, but
I put second skin audio Damplifier all throughout the cabin of an 07GT. I'd say the car went from being "pretty noisy" to "very quiet". It was basically BMW quiet.
I did the entire cabin but did not put any behind the rear seats and did not put any in the trunk. So IDK if that much noise is coming from the trunk area.
Yeah...Mustang vs vette big difference IMO. The Vette is essentially a hatchback with the rear axle being in the passenger compartment. A mustang has the rear axle behind the rear seat outside of the passenger compartment.
What I notice a ton of is heat and noise from the transmission tunnel, not so much the rear. Even with the rear seat down in car it's still not that loud. I get a bit more exhaust noise but that's it.
But I did get a few Mustang owners saying they had the same issue on the older gens because the trunk acted like a resonating drum.
Tires were also a factor in certain states.
We do have something for the tunnel and other areas but that's something you need pull the seats, lift the carpet....etc I'm trying to get a handle on if the pre cut mat we make that goes over the carpet for the trunk is good or a waste of time.
How are the roads by you. Concreate. asphalt..etc?
Thank you
All great feed back! Based on everything we are gathering it looks as though these rides can use a little quieting down.
Since we posted we too have jumped into an 06 & 03. It did seem to have the noise coming from behind.
Any more feed back from you guys is appreciated. Thank you!
Working on it my friend
Thanks
Nothing ruins a cruise faster then unwanted interior noise.
Hopefully we can help with the Stang
Thanks
Thanks
Thanks
I agree the Corvette's cargo area is a big ol drum. The run flats are an issue. Aftermarket exhaust are also a problem. There is nothing but a thin pan separating the mufflers and the rear compartment..
Thank you
Thank you
I haven't really paid attention as to the direction its coming from though (Front vs Rear). I'm heading down to Tucson this weekend. it's about a 1.5 hour drive from Chandler with more than half being concrete surface so I'll pay attention this time to see where it's coming from and how much it changes with the rear seat down/up.
I'm stock exhaust btw so very little noise from that in general.
For in city driving though, I'd say a noise mat would be a waste of time IMO.
Excellent question (Concrete vs asphalt rodas) as that does have an impact on noise. Here in AZ most asphalt highways have received a rubberized coating that reduces noise in general but, the concreted roads have not. I do get a lot of tire noise over concrete roads/highways.
It's sometimes hard to tell but please let us know if the noise is from behind. Thank you for your response
KobraKommander13
5.0L V8 Technical Discussions
03-07-2016 12:47 PM
exhaustfreak
03-03-2016 08:36 PM
DerekShiekhi
03-03-2016 04:40 AM
