Sponsored by:
Sponsored by:
How to replace antenna 2014 V6 Mustang?
Old 04-15-2016, 05:59 PM
johnlk99
johnlk99's Avatar
Default How to replace antenna 2014 V6 Mustang?
2014 V6 Mustang antenna broken off clean at the holder or cone on the rear fender. Does the antenna screw out from the holder? If so maybe can drill and tap to remove broken antenna, or does entire unit need replacement?
johnlk99 is offline
Old 04-16-2016, 07:24 PM
Siber Express
Siber Express's Avatar
Yes the Antenna does screw out. Might even be able to get it out with a small screw driver.
Siber Express is offline
Old 04-16-2016, 08:38 PM
Moderator
JimC's Avatar
I'm not sure where it broke by your write up. Do you have a picture? If it is where I think you mean, then you should be able to screw that piece out still - but if it is lower than what I am thinking then it is a little more difficult.
JimC is offline
Cal3141
01-31-2021 09:15 AM
Clean 14
02-22-2016 04:23 PM
DOM1994
08-28-2014 09:04 AM
5speed50
Wheels & Tires
05-09-2014 02:22 PM
03-246
01-30-2014 12:52 PM
Quick Reply: How to replace antenna 2014 V6 Mustang?
