Sponsored by:
Sponsored by:
Upgraded my brakes and now my ABS and Traction light are on
Old 04-23-2016, 04:21 PM
yourmyboybh1026
yourmyboybh1026's Avatar
Default Upgraded my brakes and now my ABS and Traction light are on
Ok, I'll try to give as much information as possible. I upgraded my brakes with the SVT front brake upgrade kit from American Muscle. So it has 14 inch front rotors, 4 piston brembo calipers and steel braided lines. Anyway, I put everything on, used a power bleeder to flush out my old brake fluid (I'm trying to get ready for a HPDE) and finished it off by using the old fashioned push the brake pedal technique. So I'm pretty dang sure I got all the air out of the lines. So I get everything buttoned up, wheels on and I decide to go on a test run. I turned on the car, let it warm up a minute or so and as I pull out of my driveway the wrench light comes on. I turned the car off, then back on and that went away. So I drive about a block and the ABS and traction light come on, and OFF is lite up on the traction control button. I show no codes, which doesn't surprise me since they normally don't pop up when its the ABS, but what could I check before taking it to the stealership?
Any help would be appreciated guys.
EDIT: If this happens to you, clean your speed sensors first. I had a friend suggest this to me and it cleared it up.
yourmyboybh1026 is offline
Old 04-23-2016, 05:44 PM
2007CalSpec
2007CalSpec's Avatar
I would check the wheel speed/ABS sensors.
http://iihs.net/fsm/?dir=124&viewfil...0-%20Front.pdf
2007CalSpec is offline
Old 06-11-2016, 09:50 AM
carmonch
carmonch's Avatar
Yep I'm agree it should be a sensor problem, if one of them is damage or badly conected these lights will turn on. It´s very unlikely a ABS module problem since you dotn't touched it.
I sugest lift your car again remove the wheels and check the ABC/track sensors wheel by wheel before you take the car to a dealer.
carmonch is offline
mirrormask
05-12-2016 01:09 PM
robriley3474@gmail.com
03-17-2016 09:51 AM
stwarrior23
03-15-2016 01:57 PM
IRISHROUSH
02-26-2016 11:59 AM
mohammadkhannj@gmail.com
02-21-2016 03:01 PM
Quick Reply: Upgraded my brakes and now my ABS and Traction light are on
