Sponsored by:
Sponsored by:
2010 Mustang GT idle question?
Old 04-24-2016, 01:46 PM
JeffStrongman
JeffStrongman's Avatar
Default 2010 Mustang GT idle question?
5 speed. On start up I'm hearing a low level humming noise coming from the front. Then when I come to a stop, the idle is rough. It will go from about ~800rpm and drop below ~500rpm and almost to the point where it feels like it's going to stall. Then it revs on its own up to ~1200rpm before settling back to ~800rpm. Then a few seconds later it will drop again to below 500.
A quick search says maybe idle air control valve? I live in Nevada where it can get dusty.
Any ideas on the issue would be appreciated. Thanks.
I'm taking it in on Monday. Should I suggest that the idle engine control valve could be the problem or just tell them symptoms and let them figure it out?
JeffStrongman is offline
Old 04-24-2016, 04:10 PM
kenthicken
kenthicken's Avatar
Have you disconnected the battery recently?
kenthicken is offline
Old 04-24-2016, 05:18 PM
JeffStrongman
No. Just now wrench light came on as I pulled into my garage and it stalled. Manual says "throttle control"....or something.
Old 04-25-2016, 04:34 PM
bl817
bl817's Avatar
an alternator going bad can cause these issues as well. possibly battery. have them checked. good luck
bl817 is offline
Old 04-25-2016, 08:14 PM
jwog666
jwog666's Avatar
pull codes, most likely bad throttle body
jwog666 is offline
Old 04-25-2016, 08:49 PM
JeffStrongman
Thanks for the responses. Picked car up today. They found bits of plastic in the maf sensor passage. Cleaned maf sensor. Everything seems good now. Sadly, not covered under my extended warranty as the part wasn't broken. $200 later.
Old 04-25-2016, 09:04 PM
hammeron
hammeron's Avatar
glad it was not something serious! $200 is not bad if the problem is fixed.
hammeron is offline
Old 04-25-2016, 10:58 PM
JeffStrongman
Thanks. Yeah, I guess it could always be something more serious and expensive. Kind of bummed the warranty didn't cover it. I asked the guy what if this happened to a brand new car? You're not fixing it under the warranty? I think I would go nuts if my brand new car had this problem and the warranty didn't cover it. The warranty should cover the same at mile 1 or mile 71,999.
Old 04-26-2016, 12:59 AM
JeffStrongman
My Mustang
Old 04-28-2016, 10:56 AM
SCCAGT
SCCAGT's Avatar
Warranties are for manufacturing defects. Debris in the sensor is not a defect.
Warranties, on cars anyway, are for quite a long period of time in comparison to what they used to be. And they also cover ALOT more than they used to. Nobody can cover a product forever that generates wear and tear from daily use. They would either go bankrupt, or have to charge a whole lot more for their products.
SCCAGT is offline
Quick Reply: 2010 Mustang GT idle question?
