Sponsored by:
Sponsored by:
No crank, No Start
Old 07-31-2016, 09:39 PM
eng4gewithr4g3@gmail.com
eng4gewithr4g3@gmail.com's Avatar
Default No crank, No Start
I have a 2007 Mustang GT, I recently pulled the steering rack forward in order to load and torque my control arm bolts (had some noise). Next day I get ready for work, and notice my car will not crank, and will not start.
I've tested
Battery = Good
Alternator = Good
Starter = Tested Bad, Replaced same issue with a new one, no crank, no start, same isue
I noticed that the #4 30A fuse was blown so I replaced it, cranked the car, and it blows immediately. I've checked as best I could for exposed wires, and shorts but could not find any, mine you I am no expert, I am just going by what I read.
Any input would be extremely helpful, and would save me a lot of money if I can fix it myself.
eng4gewithr4g3@gmail.com is offline
Old 08-02-2016, 02:43 PM
svastano
svastano's Avatar
Are you sure the replacement starter is good?? Just an idea,
svastano is offline
Old 08-02-2016, 03:09 PM
User 92421
IN JAIL!
User 92421's Avatar
assuming that fuse is for a starter relay? that relay could be stuck
User 92421 is offline
Old 08-03-2016, 12:02 PM
jz78817
jz78817's Avatar
Ford hasn't used a separate starter relay for decades. Fuse #4 feeds the starter solenoid. You've very likely pinched a wire when you were working down there.
jz78817 is offline
Old 08-05-2016, 04:02 PM
You were exactly correct sir, wire was pinched between the steeriing rack bolt and the (k member?) I think it's called?
thanks guys
chris452
02-29-2016 06:31 AM
67STANGX2
02-24-2016 06:20 PM
doctorpimp
02-16-2016 04:55 PM
iwantaturbo
07-23-2008 01:08 PM
BlackGT
04-02-2003 12:24 PM
Quick Reply: No crank, No Start
