clicking under dash
clicking under dash
batterydied two weeks non use charged batt starts run drives ac reardefroster an reculate lite is on will not turn off clicking under dash NEED HELP? thanks for all answers
Anyways, try resetting the Hvac controls. Although, the clicking is usually a sign that one or more hvac actuators has gone bad (stripped gears).
NOTE: The purpose of the module actuator position calibration is to allow the HVAC module to reinitialize and calibrate the actuator stop points. To carry out calibration, carry out the following steps.
Remove Smart Junction Box (SJB) fuse 10 and SJB fuse 12 for at least one minute.
NOTE: When the ignition switch is switched to the ON position, the HVAC module will initialize and calibrate the actuators. Calibration of the actuators will take approximately 30 seconds.
NOTE: If the actuator fails to calibrate correctly (mode door does not work correctly), inspect the heater core and evaporator core housing for foreign objects or debris.
Reinstall SJB fuse 10 and SJB fuse 12. Turn the ignition switch to the ON position and wait 30 seconds before verifying correct operation.
