Rear Problem
have a look at these pages. It may give you some indication of what's involved for replacement. I've done some gear replacements on my 06 GT and heard you have to be careful when removing the hub. Looks like at least your sensor is damaged.
http://iihs.net/fsm/?dir=124&viewfil...20-%20Rear.pdf
It's doable if you have the bearing split-er and press as long as there isn't more damage to the axle or something else. You can check out the parts at:
http://www.rockauto.com/en/catalog/f...ed+sensor,1912
Wheel hub and assembly with the sensor ring are further down the list.
airborneallthway
02-27-2020 03:24 AM
coffeebowl
5.0L V8 Technical Discussions
07-21-2016 10:58 PM
jonahdeich
06-30-2016 02:58 PM
