Sponsored by:
Sponsored by:
Needing some help setting up a subwoofer and amp
Old 08-25-2016, 10:49 PM
cm51
cm51's Avatar
Default Needing some help setting up a subwoofer and amp
Ive got the just of how to wire the power and ground and everything but im needing some help figuring out how to wire my amp using a LOC hooked into the rear speakers, i have virtually zero experience doing wiring so im needing any info i can get
cm51 is offline
Old 09-07-2016, 05:23 PM
rumtillidie
rumtillidie's Avatar
You can easily google it buddy, u basically wrap the wire around the positive and negative wire and run the other end into the amplifier. I tried 4 different Line out convertors but none of them received the signal properly in my 2014 mustang. I ended up paying the $310 (In Canada) to get the whole Metra dash kit and used my new stereo with the RCA wires instead.
rumtillidie is offline
Redneck1465
03-08-2016 02:04 PM
baileed
03-07-2008 12:56 AM
vfast
10-10-2003 09:50 PM
vfast
07-31-2003 06:54 PM
vfast
07-24-2003 04:29 PM
Quick Reply: Needing some help setting up a subwoofer and amp
