Burnout Now Weird Sounds
Hello All,
My 2009 GT automatic has about 67,000 miles on it. The other day I figured I would do a burnout as I haven't done one in maybe a year. I also have really old pads and rotors that I need to replace since I have been doing a TON of driving for work and personal trips. So anyways about a weeks ago I was driving and decided to do a burnout in an empty parking lot for fun. I punched the brake and gas together. Wheels spin and smoke gets created. I hold this for about 8-10 seconds? Then let off the brake and pull away with gas still fully pressed. This is the way I have always done burnouts with my vehicles with no issues.
After that my car started to make a very loud squeaking sound. I would describe it like a mix between an old rocking chair and nails on a chalkboard. It only happens from 0-10 MPH then goes away. Can only create it in drive and not reverse. It sounds like it is coming from the driver rear. I can also recreate the sound faintly by rocking the car back and forth in park with the engine off. My appointment for the rotors and pads was yesterday and I never mentioned anything to them because I actually figured the sound was from the bad pads/rotors.
Well today the sound is still there and I am starting to get worried.
Any ideas what this could be?
take it back in and say there is a noise, at least you will get them to look at it for free, who knows, maybe they bent a heat shield while doing your brakes, and its making the same kind of noise as before
This prolly does happen too often but I did a wholeshot grabbed 2nd gear and next stop sign was this chattering sound. I've snapped ped rocker bolts straight up but this was different. So I pulled the distributor and the dfivshaft to oil pump snapped like a twig!
mohammadkhannj@gmail.com
02-21-2016 03:01 PM
