Sponsored by:
Sponsored by:
Emission question
Old 10-11-2016, 08:27 PM
Goldenpony
Goldenpony's Avatar
Default Emission question
I have a 2006 GT 5 speed 'Vert. Now my car has 150K miles on the clock and runs as good as the day I picked it up new. Now here's the question, should I replace the O2 sensors? Performance is great, mileage is the same as it's always been. Should I spring for new ones?
I see 2 on the pass side and one on the drivers side. Any suggestions?
Goldenpony is offline
Old 10-13-2016, 06:06 PM
Goldenpony
Goldenpony's Avatar
Really? No thoughts?
Old 10-14-2016, 06:47 AM
cavediver
cavediver's Avatar
If it were mine, l would with that mileage. If you do, ONLY use Motorcraft, any other will likely cause issues.
cavediver is offline
Old 10-14-2016, 06:56 AM
jz78817
jz78817's Avatar
Is your check engine light on? If not, no need.
jz78817 is offline
Old 10-14-2016, 09:46 AM
Goldenpony
Goldenpony's Avatar
Nope, no CEL
Old 10-14-2016, 11:46 AM
jwog666
jwog666's Avatar
dont try and fix what isnt broken. if there was an issue with the o2 sensors, you would be flagging codes, or your mileage would be tanking
jwog666 is offline
Old 10-14-2016, 02:00 PM
Derf00
Gentleman's Relish
Derf00's Avatar
I wouldn't replace them for sake of replacing them. That's like replacing a catalytic converter for no reason other than mileage.
O2 Sensors are no more a maintenance item than the valves in your engine are. Replace the 02 sensor only if/when needed.
Derf00 is offline
Old 10-14-2016, 04:45 PM
Goldenpony
Goldenpony's Avatar
Thanks guys!
Old 10-15-2016, 09:04 AM
algregory
algregory's Avatar
I have an '05 GT in Screaming Yellow. I thought, with no foundation, that Screaming Yellow was an '05 color?
Mine looks like new, no joke. Is garage kept. Just wanted to give you a FYI FWIW - I've been using Eagle 1 wash with the Nano wax in it, and the Eagle 1 spray on wipe off Nano Wax product for the last few years. Positively glistens. I have used other products over time. I do use the "quick detailers" at times. Can't recall the last time I used a paste/liquid wax that you wait for it to dry before removing. I am sure its been at least eight years.
algregory is offline
Old 10-23-2016, 07:52 PM
Goldenpony
Goldenpony's Avatar
DK, but Screaming Yellow was on my window sticker of my 2006 GT 'Vert
Quick Reply: Emission question
