Sponsored by:
Sponsored by:
Stalling randomly when cold 5.0
Old 12-22-2016, 02:20 PM
JamesG5592
JamesG5592's Avatar
Default Stalling
On the data log it says DTC code count 1
However he did mention
U0401
JamesG5592 is offline
Old 12-22-2016, 02:41 PM
JamesG5592
JamesG5592's Avatar
Default Stalling
The P025a I believe is the code. Looking back at data log. As soon as the code count goes from 0 to 1 is starts going screwy
Old 12-28-2016, 12:32 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Duplicate
Derf00 is offline
Old 12-28-2016, 12:39 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Fuel pump control module circuit/Open...I thought only the Ford Trucks had that Fuel Pump Driver Module...?
Could be a bad fuel pump relay or a loose connection. In the 05-09 models the fuel pump driver module/relay is located in the trunk behind the plastic panel inside the trunk nearest the opening.
Other than that I'm not familiar with the newer stangs and the most common reasons for certain codes.
Derf00 is offline
