Brake Pads, easy?
replacing the fluid in the system is recommended. that said, most ppl don't. unscrew the reservoir tank lid and set it aside to relive pressure when compressing the pistons back into the calipers. do not crack the brake line at the caliper, that adds air into the system and then you will need to bleed the brakes. good luck
I replace mine at every pad change, mostly because of the road racing. Motul RBF600 and EBC Yellowstuff pads. Dusty but damn can they bring the car to a stop fast, even without the Brembos.
