Need help with blend door actuator replacement
So it seems that the only difference between the two is that the BA has some sort of optical sensor (I assume) inside and the mounting alignment slot is different. So I just took the new part, added the sensor and trimmed the slot and put it in. Seems to work but I have one question for you guys.
Does the defroster normally turn on when you run the foot AC setting? Everything seems normal except the defrost stays on for the foot setting and I dont know if thats right.
Hah, fingers crossed then if/when you finally do change things. I never use my defrost setting and one day when I did, after 5 years of not, SNAP! and it stuck....
